Topic: Communication between Arduino and PC (Read 3326 times) previous topic - next topic
gee
Hi there!
I'm trying to make a program for communication between my Arduino and the PC. I need to be able to send and receive data on the both sides. I've already written some code and the Arduino receives some bytes, but I actually don't know in which form, because the following code doesn't work properly.
Arduino side:
Code: [Select]
const int ledPin = 12;
  pinMode(ledPin, OUTPUT);
    if (Serial.available())
       if (Serial.read() ==  1)
         digitalWrite(ledPin, HIGH);
Code for the PC application:
Code: [Select]
#include <stdio.h>
#include <fcntl.h>
#include <termios.h>
#include <time.h>
int open_port(void)
int fd; //file description for the serial port
fd = open("/dev/ttyUSB0", O_RDWR | O_NOCTTY | O_NDELAY);
if (fd == -1)
printf("open_port: Unable to open /dev/ttyUSB0! \n");
fcntl(fd, F_SETFL, 0);
printf("open_port: Opening port /dev/ttyUSB0 successful! \n");
return fd;
int configure_port(int fd)
struct termios port_settings; //structure to store the port settings in
cfsetispeed(&port_settings, B115200); //set baud rates
cfsetospeed(&port_settings, B115200);
port_settings.c_cflag &= ~PARENB; //set no parity
port_settings.c_cflag &= ~CSTOPB; //stop bits, data bits
port_settings.c_cflag &= ~CSIZE;
port_settings.c_cflag |= CS8;
tcsetattr(fd, TCSANOW, &port_settings); //aply the settings to the port
return fd;
int query_modem(int fd)
char n;
fd_set rdfs;
struct timeval timeout;
char buffer;
//initialise the timeout structure
timeout.tv_sec = 10; //number of timeout secs
timeout.tv_usec = 0;
write(fd, 1, sizeof(int)); //send data
printf("Wrote.\n");
return 0;
int main()
int fd = open_port();
configure_port(fd);
query_modem(fd);
return 0;
I would be really appreciated for any help.
retrolefty
Can't say anything on the PC side as I'm not that good at PC programming. However on your Arduino side your code seems to wait for a '1' character and turns on the led. It will then stay on forever no matter what other characters you receive. Was that your intentions? Perhaps a else clause added to the second if statement to turn off the led if any character other then a '1' is received?
Lefty
gee
Yea, it actually was my intention, because I'm just testing. It's not a serious application, it's just testing for further work. But thanks for replying.
smeezekitty
Code: [Select]
115200 != 9600
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
PaulS
Code: [Select]
How big is an int on your PC? 4 btyes, probably.
Code: [Select]
Look at the return code and description for the Serial.read function. The return type is int, but that's because there is a need to return a invalid call value (when there is no data to read), but all values in the range of 0 to 255 (a byte, which is what Serial.read() actually reads) are valid, so none of them can be used to indicate invalid data. So, Serial.read() returns an int, but if the value is not -1, the actual value returned is a byte (one and only one byte).
So, you are not reading as much data, in the same way, as you are writing.
gee
smeezekitty: Thanks for finding this mistake  :)
Paul: Yes, but my intention was not to test invalid data read, but to send number "1" and then test whether number "1" was received.
I think the problem should be in this line on the PC side:
Code: [Select]
write(fd, 1, 4); //send data
Again the whole code:
PC side:
Code: [Select]
#include <stdio.h>
#include <fcntl.h>
#include <time.h>
int open_port(void)
if (fd == -1)
return fd;
cfsetispeed(&port_settings, B9600); //set baud rates
cfsetospeed(&port_settings, B9600);
return fd;
char n;
fd_set rdfs;
char buffer;
printf("Wrote.\n");
n = select(fd+1, &rdfs, NULL, NULL, &timeout);
if (n < 0)
printf("Select failed.\n");
else if (n == 0)
printf("Timeout!\n");
printf("Bytes detected on the port!\n");
return 0;
int main()
configure_port(fd);
query_modem(fd);
return 0;
Arduino side:
Code: [Select]
int incomingByte = 0;
       incomingByte = Serial.read();
       Serial.println(incomingByte, DEC);
The aim of this code is following: The PC application sends the number "1" to the port and waits for receiving the same number back. The Arduino application reads what comes on this port and then sends it back (and lights a LED). But the result - the PC application sends the byte, but Arduino doesn't receives it, because it doesn't sends it back and neither lights the LED.
PaulS
On the PC, you open the serial port. This causes the Arduino to reset. It takes the Arduino (more than) a few milliseconds to boot up and establish serial communications.
Meanwhile, you've jammed a character down the serial port, seen that no reply was received, and quit.
In the setup() function, have the Arduino send a message. Have the PC application wait for that message, and then send some data to the Arduino. Does that work?
gee
Excuse me, I don't understand the last sentence.
Quote
Could you explain to to me please?
PaulS
Quote
Think about how a telephone works. If you want to call someone, and ask a question, you don't dial the number and start speaking right away, then hang up when you don't get a response.
You dial the number ( open the serial connection) and wait for the person to answer and say hello. Then, you ask your question or make your statement.
You are not currently waiting for the Arduino to say hello.
gee
Thanks, now I understand. And please, could you suggest me a solution?
gee
If I understand, I'm supposed to sleep() my PC program for a while, is that right?
I tried, but without success.
Code: [Select]
#include <stdio.h>
#include <fcntl.h>
#include <time.h>
int open_port(void)
if (fd == -1)
return fd;
return fd;
char n;
fd_set rdfs;
char buffer;
printf("Wrote.\n");
sleep(1);
if (n < 0)
else if (n == 0)
return 0;
int main()
configure_port(fd);
query_modem(fd);
return 0;
PaulS
Quote
Is that sleep() for one second, or one millisecond? One millisecond is nowhere near long enough.
smeezekitty
http://pubs.opengroup.org/onlinepubs/009695399/functions/sleep.html
Resistors for LEDS!
gee
Quote
One second. I think it should be enough.
gee
Okay, I tried something else - sending bytes from arduino to PC. It looks quite good, but one small problem - always the 10th time I read data, I get another data as I expect.
Arduino code:
Code: [Select]
       Serial.write(1);
PC code:
Code: [Select]
#include <stdio.h>
#include <fcntl.h>
#include <time.h>
int open_port(void)
if (fd == -1)
return fd;
return fd;
int main()
configure_port(fd);
fd_set rdfs;
char incoming;
int i;
sleep(2);
for (i = 0; i < 30; i++)
read(fd, &incoming, sizeof(char));
printf("I: %d\tGOT %d.\n", i, (int)incoming);
sleep(1);
return 0;
And the result:
Code: [Select]
I: 0 GOT 1.
I: 1 GOT 1.
I: 2 GOT 1.
I: 3 GOT 1.
I: 4 GOT 1.
I: 5 GOT 1.
I: 6 GOT 1.
I: 7 GOT 1.
I: 8 GOT 1.
I: 9 GOT 97.
I: 10 GOT 1.
I: 11 GOT 1.
I: 12 GOT 1.
I: 13 GOT 1.
I: 14 GOT 1.
I: 15 GOT 1.
I: 16 GOT 1.
I: 17 GOT 1.
I: 18 GOT 1.
I: 19 GOT 1.
I: 20 GOT 1.
I: 21 GOT 1.
I: 22 GOT 1.
I: 23 GOT 1.
I: 24 GOT 1.
I: 25 GOT 1.
I: 26 GOT 1.
I: 27 GOT 1.
I: 28 GOT 1.
I: 29 GOT 1.
As you can see, the program is always supposed to read number 1, but in the tenth case (i = 9) I get 97. And it's not random, I always get wrong data (sometimes another numbers) in the tenth case. Am I doing a mistake somewhere?
