Loading...
Pages: 1 [2] 3   Go Down
Author Topic: ENC28J60 vs Wiznet: what's the CURRENT status?  (Read 8331 times)
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Also, MDfly is selling a board based on this chip for $17.  http://www.mdfly.com/index.php?main_page=product_info&cPath=9_41&products_id=109
They're sold out now, but I managed to grab one while still in stock.  The price was just too temping, although it's clear that bringing it up is going to be a giant pain from everything I see written out there.
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Pinging this thread up again, in case anyone finds it while trying to make this same decision.
After investing a couple of months in the ENC28J60, I strongly recommend ANYTHING ELSE smiley  The big problem with the TCP/IP stack in software is that it's really unreliable.  There is not a big community using this chip, so the stack does not get the benefit of crowd-sourced bullet-proofing.  I've now installed and tested every implementation I could find, and I can't find anything that works as a client which is reliable and remotely easy to use.
Quote
But what is a big deal in this case is reliability:  some of the sensors will be installed in locations where it would be an all-day trip to push the reset button,  so it's important that there are no mystery gotchas in the drivers that cause the system to flake out once a week,  or even once a quarter.
This is exactly what I'm finding happening.  So now I'm working on a watchdog reset solution.  But still, the mean time to failure in my system is about an hour of sending packets once a minute.
Logged
london
Offline Offline
Full Member
View Profile
yuo might want to checkout http://wiki.hackspace.org.uk/wiki/Project:Nanode
Logged
Seattle, WA
Offline Offline
God Member
View Profile
WWW
Cool..  Nanode is pretty nifty, I might want to make something like that!  Problem is, Nanode uses EtherShield.  Same problems as stated above smiley-neutral  Piles of complexity...  Where do you even start if something goes wrong.  Less cleaned up than EtherCard.
Logged
Wellington, New Zealand
Offline Offline
Sr. Member
View Profile
Have you seen the Freetronics EtherTen? Its basically an Arduino UNO plus the Wiznet Ethernet Shield combined into one (SD card slot included).  It also supports Power over Ethernet, both a cheap version of PoE and the official version of PoE.
I bought one to act as the controller for a zigbee network and it took almost no time to load the standard web server example sketch and get it running (the one that returns readings from the analog pins).
« Last Edit: May 23, 2011, 07:34:20 am by dhunt » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
You can use the last library from : http://blog.thiseldo.co.uk/?p=504>
I try it on a arduino mega with .jpg file, and he works fine.
gg
Logged
France
Offline Offline
God Member
View Profile
Librairies for EN28J60 chip are better end better....
-el-egg tells about thiseldo's one
-jcw (Jeelabs) is making a version allowing cleaner and clearer code :
http://jeelabs.net/projects/cafe/wiki/EtherCard
Good things like 'sleep mode' are coming for ENC28J60 :
http://blog.derouineau.fr/2011/07/putting-enc28j60-ethernet-controler-in-sleep-mode/
In my case the choice among available chips was :
-W5100 for a current work with 'server mode',
-ENC28J60 for a another app with 'client mode' feeding Pachube/ThingSpeak (no permanent ethernet connection, low power mandatory)
(New chip arrives : Wiznet W5200 with power down pin, Microchip ENC24J600 ....)
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
The ENC28J60 is at more or less 8 or 15 euros, the other is at 25 to 30 euros ( but the lib
are built-in in arduino software.
For the ENC28J60 you need to add the lib but he works fine with this last version ( no to big html page ).
See the example in the lib.
I also find a way to put more html pages in the web server and also a image for the background.
// File d1.jpg in hex
prog_char d1[] = {
  0xff,0xd8,0xff.....
};// number of chars = 767
// The bg.jpg send procedure
uint16_t web_bg(uint8_t *buf)
  uint16_t plen;
  plen=http200_img_ok();
  plen=es.ES_fill_tcp_data_len(buf,plen,bg,767);
  return(plen);
S
Logged
Germany
Offline Offline
Newbie
View Profile
WWW
I don't know why ICs like ENC28J60 or W5100 / W5200 / W7100 should be much more than 6 Euro !
Where do you order?
I'm working indirectly for WIZnet, so I'm not independent. I'm prejudiced.
but, ! both chips cost less or around 6 Euro, for small quantities !.
--- please allow me a small commercial advertisement <adv> ---
See here what is possible on a small MCU + W5200:
http://www.dacomwest.de/eng/e_new_evb90363web.htm (open source Web server with Sensors and graphical 3D I/F, Java-Script, DHCP and SMB)
It's stable for weeks, month, and years. Sorry Microchip, I don't believe ENC28J60 can do that.
And this W7100 (4in1) is a 5 to 6 Euro IC (8051 + engine like W5200) in one silicon chip.
The W5200 is a 3 to 4 Euro chip (3in1: HW TCP/IP + MAC + PHY)
If you are private, ask www.Watterott.com to organize it for you. Sorry, Dacom West is for German B2B only (no online shop).
--- </adv> ---
I like Microchip and Atmel the same in MCU, and I just wanted to point out possibilities and correct price ranges when it comes to Ethernet.
BR, Joachim Wülbeck, FAE, Dacom West GmbH
Logged
FAE at Dacom West GmbH
www.dacomwest.de
France
Offline Offline
God Member
View Profile
For me, 4jochen, the good news is :
Quote
Good candidate for a new module (Wiz812 like, with direct fast SPI driving).
"Related Modules" needs something in W5200 column !
(W5200E1 Evaluation board is something else...)
« Last Edit: August 17, 2011, 06:03:56 pm by al1fch » Logged
Germany
Offline Offline
Newbie
View Profile
WWW
Hello Arduino-Forum,
WIZnet proudly presents ....
WIZ820io is an embedded Module using WIZnet's W5200 !!!
WIZ820io: http://www.wiznettechnology.com/Sub_Modules/en/product/Product_Detail.asp?cate1=&cate2=&cate3=&pid=1161
The W5200 + some externals + crystal is on the Bottom-Side of the small PCB. The footprint is 100mil = 2.54mm pitch.
The two 6pin rows are 800mil = 8x2.54mm = 20.32mm wide. The PCB is 23mm wide and 25.62mm = 1inch long, the MagJack app. ~2.5mm overboard.
best regards,
Joachim Wülbeck
Logged
www.dacomwest.de
France
Offline Offline
God Member
View Profile
Quote
Thanks 4jochen for this news !!
Open Source ...Good point for Wiznet....
« Last Edit: August 30, 2011, 03:03:22 pm by al1fch » Logged
'round the world...
Offline Offline
Edison Member
View Profile
WWW
best regards,
Joachim Wülbeck
WOW.
Logged
Eu não sou o teu criado. Se respondo no fórum é para ajudar todos mediante a minha disponibilidade e disposição. Responder por mensagem pessoal iria contra o propósito do fórum e por isso evito-o.
Se realmente pretendes que eu te ajude por mensagem pessoal, então podemos chegar a um acordo e contrato onde me pagas pela ajuda que eu fornecer e poderás então definir os termos de confidencialidade do meu serviço. De forma contrária toda e qualquer ajuda que eu der tem de ser visível a todos os participantes do fórum (será boa ideia, veres o significado da palavra fórum).
Nota também que eu não me responsabilizo por parvoíces escritas neste espaço pelo que se vais seguir algo dito por mim, entende que o farás por tua conta e risco.
Dito isto, mensagens pessoais só se forem pessoais, ou seja, se já interagimos de alguma forma no passado ou se me pretendes convidar para uma churrascada com cerveja (paga por ti, obviamente).
Germany
Offline Offline
Newbie
View Profile
WWW
I like "WOW" as reaction.  smiley-cool
And "open source" means, open hardware and open code.
The schematic you can allready see at the EVB: W5100E01-M3 -> downloads.
And a lot of driver and applications source code is already available also.
Maybe we can compare W5200 vs. W5100 with a simple "new" ethernet-shield (simple perfboard, german:Lochrasterplatine) soon.
Who will adopt the driver first?
looking forward and best regard, Joachim
Logged
www.dacomwest.de
France
Offline Offline
God Member
View Profile
Hi 4jochen !
Quote
If someone adapt 5100 driver for 5200, I could be the first to adopt it !! smiley
More serious : Cortex M3 working code helps 5200 data sheet hands on...
Driver is in this project :
http://www.wiznet.co.kr/UpLoad_Files/ReferenceFiles/W5200_TCP_and_UDP_SampleCode_v1.0_kr.zip waiting for AVR/Arduino porting .....
Any idea about (approximative) unit price (hobbyst) for WIZ820io ? about 10€ if chip is 3 to 4 € (reply #23)
Quote
« Last Edit: August 31, 2011, 03:08:47 am by al1fch » Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
