Topic: Arduino 101  (Read 3486 times) previous topic - next topic
jc14aba
I am a university student in my final year and i have been the project of creating a stabilized platform for an rc aircraft to carry a camera on. Basically what this means is i have to develop a platform to fit inside a small aircraft and no matter what the aircraft does (pitches up or down, rolls left of right) the platform stay flat and level as to not distort the image.
Now on to what i wanted to ask. Does anybody on here know will the Arduino/Genuino 101 be a suitable micro controller for this application, as my preliminary research says to me it will, as it has the micro gyroscopes already fitted onto the board, which i need to be able to measure the movement of the aircraft. Any help or information would greatly appreciated.
Thanks
Jack
pert
The form factor of the 101 doesn't seem very well suited to that project because it's larger and heavier than it needs to be.
RayRandom
The 101 is overkill. You can get gyro devices for regular Arduinos on banggood.
You might want to note, though, that Steadicams are mechanical, not electronic.
jc14aba
Thanks for your comments ill be sure to look at what RayRandom has said, as an extension to that could you recommend a board to use as this has sort of threw a spanner in the works as i thought i was all set with the 101.
Also if i was to get the gyros from else where would they need to be attached onto another PCB or is there a micro controller on here that offers the ability to attach them directly to it without the need for other boards?
Also the platform will be carrying a camera no bigger than a go-pro.
(im relatively new to this type of electrical engineering hence some of the silly questions i may ask)
Thanks
Jack
