Loading...
Pages: [1]   Go Down
Author Topic: What's it called? (looking for part)  (Read 1173 times)
Around St. Louis
Offline Offline
Jr. Member
View Profile
Ok, I'm looking for the name of what I would call a stepping potentiometer.
Pretty much I want a turn dial, but I want it to have 6-8 turn stops. Like a Extra High, High, Medium, Low, Extra Low turn knob. What are these called, and where can I get them? I looked on ebay for step potentiometers and found things called Attenuator Potentiometers, but those are like 24 steps (way to many for what I want) or higher. They are also much larger then I want. Anyone know what I am talking about?
T__T I hope someone replies. It's a pretty simple question. I just don't know what they are called.
What I'm wanting to do with this is make a configuration circuit out of this type of thing and a few buttons. Any help would be appreciated.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Do you mean something like this?
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=GH6101-ND
Or do you really just want a potentiometer that you will read a voltage from?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
pot with "detents", that's the term you were looking for
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P12427TR-ND
Logged
Around St. Louis
Offline Offline
Jr. Member
View Profile
That's kind of what I wanted, but I only wanted the 3 pin variety (1 input voltage, 1 ground, 1 output).
My brother suggested I look for rotary switch, but those have a lot of output pins also. I'm wanting to be able to hook up one knob to one analog signal.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Do a search for "potentiometer with detents" , see what comes up - 'detents' is the key you were after.
« Last Edit: January 30, 2011, 07:56:32 pm by CrossRoads » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
I think your going to have a very difficult problem finding something like that. Your brother is right. Use a single pole 6-8 position rotary switch. Then wire a 6-8 series resistor voltage divider. Then wire the junctions of the resistors to the switch contacts and the switch common contact becomes your output voltage.
Lefty
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
The part I referenced earlier, while surface mount, has this schematic, which I believe is what was asked for.
Just need to buy the shaft that goes with it and wire it up.
Or, look for Non-surface mount versions of "POT 10K OHM WITH 12 DETENTS SMD"
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
There are a number of pots with detents on this site
http://www.potentiometers.com/alps_rotary.cfm
Do some googling, someone must be a distributor for them.
Logged
Pages: [1]   Go Up
Print
Jump to:
