Topic: New library for RF22, RFM22 radio modules (Read 23198 times) previous topic - next topic
mikem
Hi All,
I have uploaded a new library for interfacing with HopeRF RF22, RFM22 and compatible radio transceivers.
It is very flexible and can be used in a wide range of applications.
It has been extensively tested and its rock solid and very fast.
This library provides functions for sending and receiving messages of up to 255 octets on any frequency supported by the RF22, in a range of predefined data rates and frequency deviations. Frequency can be set with 312Hz precision to any frequency from 240.0MHz to 960.0MHz.
Up to 2 RF22 modules can be connected to an Arduino, permitting the construction of translators and frequency changers, etc.
This library provides classes for
RF22: unaddressed, unreliable messages
RF22Datagram: addressed, unreliable messages
RF22ReliableDatagram: addressed, reliable, retransmitted, acknowledged messages.
The following modulation types are supported with a range of modem configurations for common data rates and frequency deviations:
GFSK Gaussian Frequency Shift Keying
FSK Frequency Shift Keying
OOK On-Off Keying
Support for other RF22 features such as on-chip temperature measurement, analog-digital converter, transmitter power control etc is also provided.
Example client and server programs are provided.
Documentation and download details are at http://www.open.com.au/mikem/arduino/RF22
mikem
Now updated to version 1.1
Added 2 new sample programs:
rf22_snoop Dumps in ASCII the contents of all RF22 messages received
rf22_specan Simple spectrum analyser using the RSSI measurements of the RF22
X3fil
I've tested it a little bit and it works, great work!! :)
Is the structure library able to use a point-multipoint scenario? I think I've to use reliable datagram version. I'm planning to have more clients and one server. I'll play meanwhile a little bit
Thank's a lot!!!
Simon
mikem
HI,
yes, provided the clients all have different addresses from each other and the server, you can have as many clients as you wish (up to 255).
Cheers.
mikem
Im thinking about making a network mesh router class with this, al-la XBee. Any interest?
Cheers.
X3fil
Cheers.
If you could give me a little bit more details I could...
At the moment if I bring work 3 rfm22 is a great goal for me, but with this library it's most done :-)
mikem
One of the nice things about the zigbee/xbee radios is that you can set up a mesh network of them and they will arrange to route messages from hop to hop across the network to deliver messages between radios that cant directly hear each other. They are self healing networks that discover the best route between nodes and if intermediate nodes disappear or go off the air, a new route will be discovered.
Thats pretty cute but more than most people need. Still it sounds like an ionteresting challenge.
X3fil
This is really interesting! I don't think I need it for now, but btw its a nice feature. In real I've no idea where to put these radios also could be possible some are not in range from the server. In this case that would be a solution.
A kind of repeating system. The modules should act as bridge if the packet is not for himself... sounds really cool!
mikem
Im making good progress with this. Now have reliable multi-hop message delivery with hardwired routing.
Biggest problem at this stage is lack of RAM in the Arduino. Running out of room for buffers etc.
Soon, automatic route discovery?
Cheers.
mikem
New version 1.2 has now been uploaded with 2 new classes:
- RF22Router: multi hop delivery from source node to destination node via 0 or more intermediate nodes
- RF22Mesh: multi hop delivery with automatic route discovery and rediscovery.
These allow  support of some of the features of ZigBee and XBee,
(such as mesh routing and automatic route discovery),
but with a much less complicated system and less expensive radios.
Sample programs are included, along with support for simulating various network topologies.
Documentation and downloads at  http://www.open.com.au/mikem/arduino/RF22/
FrankRadio
Hi Mike, i'm studing in detail your 1.5 lib.
Now how we can set-up the module without use the external interrupts pins?
I have my own lib but i'm not using the int inputs
Is not very clear, but the packet payload is about 255 bytes rigth?, i mean we can transmit 255 in FIFO mode?(the internal bufer is about 64bytes)
Can we use four digits as node ID? i mean 2F2F as ID for example?
I can test all this because i got a lot of RFM22 modules.
Best Regards
Frank
mikem
Yes, the max payload is 255 octets.
Node IDs are limited to 1 octet.
Cheers.
FrankRadio
Hi Mike!
Are you using frec hopping or only a conventional frec at the library?
Other thing is, how do you do when you ask at mesh for other node to send his beacon and two nodes can send the beacon, how them know that one must Tx before other?, have some order for this? the node Id for example?
At router's table, it use RSSI as variable to decide how will be the next node to send the packet?
I will write an encription library for the data payload
Best Regards
Frank
mikem
Frank:
No frequency hopping is used.
Random retry timers are used for reliable datagrams
Router table does not use rssi to decide: last reply wins
Cheers.
FrankRadio
Have you all the network operation theory writed in some document?
The only thing that i can't understand about MESH is if each node repeats each datagram, how this datagram first reach the destination node after jump several times, and how the destination NODE respond to this datagram. I think that in both cases they will not use the same node. I think that the route have different direction.
I mean, if the server wants to send a command to the last node in the network, at the firts node that repeat the datagram it will be send back to the same node that generate this datagram, how the node send to others nodes and not go back to the server?
I must read some theoryy!!
Best Regards
Frank
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
