Author Topic: EL Wire  (Read 3453 times)
Los Angeles, CA, United States
Does anybody know if 50 feet of El Wire can be controlled by an arduino?
C program run. C program crash. C programmer quit.
Z
Australia
There is an EL tutorial at adafruit.
EL needs a much higher voltage than an arduino can supply
North Yorkshire, UK
I think the issue here might be the 50'.
Yes you can control EL wire with an arduino, whether you can find an inverter to drive 50' is another matter.
I don't know how much these systems can drive - perhaps 50' is easily possible - I dunno.
SparkFun sells an Arduino shield that controls 8 EL circuits: http://www.sparkfun.com/products/9259
They now also sell a couple versions of the voltage inverter that creates the required 110VAC to light them up.
Wall Adapter EL Inverter  http://www.sparkfun.com/products/10202
EL Inverter - 3v  http://www.sparkfun.com/products/10201
Yeah, I saw those earlier. I have $10 Sparkfun free day credit. I am still comparing this to other possibilities.
Glasgow, scotland
heh, i feel for you.  Sparkfun freeday was a rampage against patience.
hello, is
 may work the wire
 without investing?
 or power
 to inverter
 recycled materials?
Always making something...
I would advise you NOT to use Sparkfun's board for 50 feet of wire!
Several months ago, I worked on a big project with 114 pieces of el wire, each 8 feet.  Here's my blog about it:
http://dorkbotpdx.org/blog/paul/hand_eye_supplys_starlight_parade_float_wins_award
Unfortunately, we used those Sparkfun controllers, and they were nothing but trouble!  Here is a blog post I wrote about all the technical problems.
http://dorkbotpdx.org/blog/paul/sparkfun_el_sequencer_trouble
The Sparkfun board probably isn't so bad for a tiny project, where you have 8 pieces of wire ranging from several inches to maybe a couple feet.  We used 8 feet on each channel, and it was a new higher brightness wire which has more capacitance.  So 8 feet of this wire is like using perhaps 40-some feet of "ordinary" wire (though the trend seems to be newer wires are brighter and heavier loads).
The really terrible problem with those Sparkfun designs is you can't switch at the AC waveform zero crossings.  With el wire (or any purely capacitive load), switching near the zero cross point is critically important.  If you trigger the triac near the crest of the waveform, you're suddenly applying a massive voltage to a capacitor.  The current flow is incredibly high for a very brief moment.  For short, older-style wires, it's not enough to damage the triac.  But 50 feet is quite a substantial load.
If you search the web for info about triacs, everything is regarding resistive and inductive loads, at 50 or 60 Hz.  The rules are entirely different for a capacitive load.  With an inductive or resistive load, you can switch at any point in the waveform, and dimmers do exactly that to control effective brightness.  The problems with inductance come in regarding excessive rates of voltage change due to the inductance.  But with capacitance, the issues are completely opposite.  Switching capacitors causes huge surges in current rather than incredibly fast changes in voltage.  Small triacs simply can't handle those huge peak currents reliably, so you must switch at the zero crossings.
The simplest solution, and what I believe Sparkfun is eventually planning, involves using an optocoupler which has a zero cross switching detector built in.  If you're going to control 50 feet of wire, do yourself a big favor and look for a solution with zero cross switching built in.  You could also build a zero cross detector circuit and interface it to an interrupt pin.  But that solution is a bit risky, because a bug in your code could stress or destroy the triacs.  With the Sparkfun design, you don't even have any way to know when the zero cross is near, so your only option is to just trigger the triac at some random moment (relative to the AC waveform) and hope you don't stress the triac too much.  It's a very poor design.
If you go with Sparkfun's board, you'll have nothing but trouble using such long wires.
« Last Edit: December 17, 2011, 04:57:54 am by Paul Stoffregen » Logged
hello
 thanks for the response
 what I want is to ride my
 own inverter
 therefore
 wonder if it is possible
 and if anyone has any tutorial
  I have to mount a tron costume
 the wire
