So if the fan can use only 0.07 A, why isn't it possible for the optocoupler?
Well you were asking at first about switching 25A, but for a fan you still need a extra transistor because a typical opto coupler transistor can not supply 70mA. Check the data sheet for the specific type of opto isolator you want to use. For the 4N35 the data sheet says the maximum output current is 50mA.
Note also that the 70mA quoted is probably the running current, typically this is much lower than the start up current or the stall current.
Note you also need a resistor between the arduino and the opto coupler. This is because it is really just and LED and you need a current limiter. You also need a pull up resistor on the gate of the FET to the +12V.
everthing works fine, except, it wont turn off. When a put the multimeter on the mosfet G and S. It goes off and on. Maybe it's the pull up resistor what i need?
It seems, that the voltage stays high when its put high. The mosfet acts like a switch, when high i disconnect the gate, it stays high, when low, i disconnect it stays low. So why doesn't it go low, but only high. I just started with circuits. I'm a programmer, sorry for the stupitty
I think I see several wiring errors, but I refuse to try and make sense of such pictorial pictures, when what is really required is a proper schematic drawing. However hang on for others that might have a higher threshold of pain the I do.
That circuit is not right. There is a common ground on both sides of the circuit, this means it is not isolated. As lefty says it is very difficult to follow a physical layout and generate a schematic from that. In fact is is impossible for anything but the most trivial circuit. You must have a schematic because you made it (you can't pretend to make anything without a schematic) so could you post that. Even a photo of a hand drawn one would be fine.
It is much easier generating a physical layout from the schematic. But you don't look like you have got it quite right yet. Also is the FET part number correct?
I'm just started learning electro. I will post a schematic tonight. The fet name is right I think, I have to double check maybe. So if I understand, common must be seperated. But the + also goes to the optocoupler, I think thats also not right.
The opto coupler has two sides, it is quite alright for the + and ground to go the opto providing that only fan and fet connections go to the output side and only arduino and arduino ground go to the input side.
Don't connect anything to the base of the opto transistor. Connect the emitter to the gate and the collector to the +12V, then a pull down from the gate to ground.
The fan should be connected to the +12v with the other end to the FET drain. Finally the gate pull down and the -12V to the FET source.
Yes that new circuit is what I meant.
The gate pull down resistor (the resistor's end not connected to the gate) and the source and the -12V all to the same point just like you have.
Can the +12 to optocoupler collector be avoided? Because +12 has 30 A.
The fact that the 12V supply can provide 30A should be of no concern to you nor the transistor. The current drawn will only be in accordance with Ohm's law, and if that doesn't dictate 30A then 30A will not flow. The important thing is that the 12V supply is totally isolated from the arduino circuit.
is it save to solder the 4n35.
Yes
Does the high temp destory the IC?
Only if you take more than ten minutes with the soldering iron on it.
Maybe this sounds stupid. But what is the use of the FET at this setup? The voltage of the fet and the optocoupler is same right?
Ok, I went for it and connected to the psu 12 volt. And it worked !!! No failure or damage. The fet doesn't get hot nor the optocoupler. I can read the rpm and I'm now working on the tempreader. Soon more updates and pics.
