Topic: Small mistake in Reference (Binary Integer Constants) (Read 3259 times) previous topic - next topic
timograw
Hi, i think i found a small mistake in http://www.arduino.cc/en/Reference/IntegerConstants
binary constants are supposed to look like this
 0bxxxxxxxx
or
 0Bxxxxxxxx
and not as described a simple B.
westfw
The 0b01010101 format is a gcc extension, and not standard C.
The B00101010 format is something provided by "binary.h" in the library include files (a bunch of ordinary preprocessor symbols assigned the appropriate binary values.)
This means that the Bxxxx format is more portable to other compilers.
frank26080115
which other compiler will accept the Bxxxxx format without that huge definition file?
westfw
None, and neither does gcc.  But the huge definition file is completely standard and should work with any compiler.
westfw
You can also keep an eye out for this neat set of macros that lets you specify binary constants like:
PORTB = B8(1010);
http://bytes.com/topic/c/answers/216333-binary-constant-macros
