Loading...
Pages: [1]   Go Down
Author Topic: 3.6V .5W zener diode appearance  (Read 1468 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
What does a 3.6V .5W zener diode look like? I'm attempting to build something with some salvaged (free) parts, but I'm not sure what to look for before desoldering.
Logged
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
Probably like this (though there are lots of other possibilities):
The Quick Shield: breakout all 28 pins to quick-connect terminals
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Here's a picture from digikey:
Note that 0.5W zeners from a particular manufacturer are going to look alike regardless of voltage, except for the part number that may or may not be legible...
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Darn, looks like I am going to just have to keep desoldering until I find something with markings that match one on digikey.
I have quite a few of both types so far, but none of them have the correct specifications.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
You are best getting the numbers off the parts you remove and typing them into google followed by the words data sheet. That should tell you what they are. Remember that any wattage rating above 0.5w will do just as well.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
+1
It is almost impossible to tell the difference between a diode and a zener diode without the label.
How ever, with some good will you could make a test jig with, lets say 20Vdc and a 20kOhm R. If you connect your "zener diode?" forward you will have typically 0,6 to 0,7V over diode and if connected backward you will see the zenervoltage. It will of course not work if Zener voltage is over 20Vdc, and if it is a regular diod it will stop backward and you will measure 20V.
Edit: You may be better of with a 4,7kOhm R and you should be aware of that forward voltage can be higher maybe 2V or so. This is not bulletproof but it should work for most zener diodes out there.
Thank you
« Last Edit: January 31, 2011, 04:12:38 pm by swetrack » Logged
Pages: [1]   Go Up
Print
Jump to:
