Topic: Aduino Uno + XBee Shield (Read 2460 times) previous topic - next topic
wixspot
We purchased 2 Arduino Uno boards (Adafruit)+ 2 XBee Shields Series 2: http://www.robotshop.com/Arduino-Xbee-Shield-Wireless-Module-7.html
Has anyone figured out how to get these 2 talking? The documentation claims that series 2 is not compatible with series 1 and the tutorials online seem to be for series 1. When you click on the link http://arduino.cc/en/Guide/ArduinoXbeeShield  that says: For the XBee ZNet 2.5 ("Series 2") modules, see this configuration guide - the link http://www.humboldt.edu/~cm19/XBee%20setup.pdf does not exist.
This is a high school project and all we want to do is send a simple message from 1 board to the other, wireless and display that message on a LCD. The arduino uno and lcd work fine. Only the xbee shields do not seem to communicate.
Any ideas? Please help!!!
mowcius
The tutorial should work for the series 2 apart from you need to set one of your modules to router.
What have you set them to/done already?
Have you been using X-CTU to configure them or have you been configuring them by commands?
pracas
go to digi.com and download XCTU. Then configure both modules to be Znet end devices and it will start working.
Be The Change...
mowcius
Quote
Pretty sure it's not that simple when you're using the XBee shields. I think you have to use the command interface.
pracas
Quote
well i think u can remove the ic off the arduino board and put the shield on usb mode[jumpers] and then use them together as a usb explorer.. don't have windows to try it thought but remember doing it that way...
Be The Change...
mowcius
Quote
Yeah maybe you can - Anyway wixspot seems to have vanished.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
