Topic: Re: Arduino Codes not Uploading (Read 200 times) previous topic - next topic
captainnewman
Hi
I am in need of your help, which I am sure you can give me advice accordingly.
I undertook an electronic project recently using 'Arduino Uno' module for ultrasonic parking sensor. There is plenty of support stuff out there, like YouTube and Arduino themselves.
The problem is that every time I upload the  'Code' it is filled with errors, even when I go to the Arduino library and install from their own site, I have checked the system I have (China make? CH340)) and installed the correct drivers then tested the 'up load' of the 'blink program' which works well even making successful changes to the time sequence.
I tried to install other copy codes, but no go.
I hope you can solve this issue for me, thanking you
captainnewman
sterretje
#1
Oct 16, 2017, 04:21 pm Last Edit: Oct 16, 2017, 04:21 pm by sterretje
Hi
captainnewman
It would help if you posted the code and the errors.
Use code tags when posting code or error messages.
Type [code]
Paste your code or full(!) error message after that
Type [/code] after that
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
