Topic: [Solved] Problems accessing parallel SRAM (Read 15516 times) previous topic - next topic
leo72
Feb 01, 2011, 12:48 am Last Edit: Feb 03, 2011, 12:32 am by leo72 Reason: 1
I'm learning parallel interfacing and I'm using an 8Kx8 SRAM from Cypress (CY7C185) in DIP28 format.
I use 3 74HC595 S/P shift registers, 1 74HC165 P/S shift register and an Arduino Uno.
I used 2 of the 74HC595 s/r to translate the address from serial to parallel, the other 74HC595 to read/write the data through the I/O bus of the RAM and the 74HC165 P/S s/r to convert the read data from parallel to serial.
In attachment you'll find the schematic of my project. The pins on the left are the Arduino pins.
This is my code. It simply tries to write some data into the SRAM and them tries to write the values into the EEPROM of the uC for a further check.
Code: [Select]
/* CONNECTION TEST TO A SRAM CHIP OF 8Kx8
USING 2 74595 SHIFT REGISTERS TO MANAGE THE ADDRESS,
1 74595 TO MANAGE THE DATA TO BE READ/WRITTEN INTO THE RAM
AND 1 74165 P/S SHIFT REG. TO READ DATA FROM RAM
#include <EEPROM.h>
// Connecting the pins
//1st and 2nd 595
#define data1pin 0 //pin DS
#define latch1pin 1 //pin ST_CP
#define clock1pin 2 //pin SH_CP
//3rd chip 595
#define data2pin 8 //pin DS
#define latch2pin 9 //pin ST_CP
#define clock2pin 10 //pin SH_CP
//this is common for all the 3 595s
#define master_reset 3 //pin MR/ of the 3 chips
//SRAM Chip
#define ram_we 4 //pin WE/
#define ram_ce2 5 //pin CE2
#define ram_oe 6 //pin OE/
#define ram_ce1 7 //pin CE1/
//chip 165
#define clock3pin 11 //pin CP
#define set_load 12 //pin PL/
#define load_data 13 //pin Q7
/* SRAM
TO WRITE:
CE1/ -> LOW
WE/ -> LOW
CE2 -> HIGH
OE/ -> LOW
TO READ:
WE/ -> HIGH
CE1/ -> LOW
OE/ -> LOW
CE2 -> HIGH
#define READ 2 //RAM status: prepare it for reading
#define WRITE 1 //RAM status: prepare it for writing
#define DISABLE 0 //RAM status: disable it
void clear_shift_registers() {
   //cleans the internal registers of the 595 s/r
   //avoiding old datas to be read instead of new ones
   digitalWrite(master_reset, LOW);
   delay(50);
   digitalWrite(master_reset, HIGH);
void set_ram(byte stato) {
   switch (stato) {
       case DISABLE:
           digitalWrite(ram_ce1, HIGH);
           digitalWrite(ram_oe, HIGH);
           digitalWrite(ram_ce2, LOW);
           digitalWrite(ram_we, HIGH);
       case WRITE:
           digitalWrite(ram_ce1, LOW);
           digitalWrite(ram_ce2, HIGH);
           digitalWrite(ram_we, LOW);
           digitalWrite(ram_oe, LOW);
       case READ:
   //initial pin setup
   pinMode(master_reset, OUTPUT);
   //pin of the shift registers 1, 2 and 3: OUTPUT
   pinMode(latch1pin, OUTPUT);
   pinMode(clock1pin, OUTPUT);
   pinMode(data1pin, OUTPUT);
   pinMode(data2pin, OUTPUT);
   pinMode(clock2pin, OUTPUT);
   pinMode(latch2pin, OUTPUT);
   //RAM pins: OUTPUT
   pinMode(ram_we, OUTPUT);
   pinMode(ram_ce1, OUTPUT);
   pinMode(ram_ce2, OUTPUT);
   pinMode(ram_oe, OUTPUT);
   //S/r 165
   pinMode(clock3pin, OUTPUT);
   pinMode(set_load, OUTPUT);
   pinMode(load_data, INPUT);
   //initialize
   clear_shift_registers();
unsigned int indirizzo; //the address to be used
byte valore = 0; //the value to be used
int eeprom_pointer = 0; //pointer to EEPROM location
   // clear 10 locations in the SRAM and then write a sequence of numbers
   for (indirizzo = 0; indirizzo <10; indirizzo++) {
       scrivi_ram(indirizzo,valore);
       valore += 3;
       EEPROM.write(eeprom_pointer, valore);
       eeprom_pointer++;
       delay(10);
   //read the first 10 bytes and then write them into the uC EEPROM
   for (indirizzo = 10; indirizzo < 20; indirizzo++) {
       valore = leggi_ram(indirizzo);
       delay(10);
   delay(5000);
   //delay
void scrivi_ram(unsigned int indirizzo, byte valore) {
   byte hbyte, lbyte;
   //write the address into the shift registers 1 and 2
   digitalWrite(latch1pin, LOW);
   digitalWrite(latch2pin, LOW);
   hbyte = highByte(indirizzo);
   lbyte = lowByte(indirizzo);
   shiftOut(data1pin, clock1pin, MSBFIRST, hbyte);
   shiftOut(data1pin, clock1pin, MSBFIRST, lbyte);
   //write the value into the 3rd s/r
   shiftOut(data2pin, clock2pin, MSBFIRST, valore);
   //write the value into the RAM
   set_ram(WRITE);
   digitalWrite(latch1pin, HIGH);
   digitalWrite(latch2pin, HIGH);
   delay(10);
   //disable all the chips
   set_ram(DISABLE);
byte leggi_ram(unsigned int indirizzo) {
byte valore, hbyte, lbyte;
   //read the content of the byte "indirizzo"
   //write the address
   //wake up the SRAM and set it for reading
   set_ram(READ);
   digitalWrite(clock3pin, HIGH);
   digitalWrite(set_load, LOW);
   delayMicroseconds(5);
   digitalWrite(set_load, HIGH);
   set_ram(DISABLE);
   shiftIn(load_data, clock3pin, valore);
   return valore;
But reading the EEPROM I only get the values written in the first 10 bytes during the first pass, when my code tries to write to the SRAM, but I don't find any value in the last 10 bytes (I only find the default values, $FF).
I cannot understand how to pilot this device.
EDIT: I uploaded an english version of the code, to better understand my ideas
CrossRoads
Why do you have OE low when you trying to write the SRAM? I think this would interfere.
The Datasheet shows OE High during writes to the part.
leo72
#2
Feb 01, 2011, 09:17 am Last Edit: Feb 01, 2011, 09:40 am by leo72 Reason: 1
Thank you for the suggestion. I'll try it.
EDIT:
didn't solve my problem....  :~
PaulS
Pin 13 has a resistor to go with the on-board LED. Perhaps using a different pin for the load_data pin would be a good idea, since that pin needs to be an INPUT pin.
Grumpy_Mike
You are using D0 and D1 (or Pin 0 and Pin 1) on the arduino, these are best left for the serial communications. Use pins 14 and 15 (analogue pins 0 and 1) instead.
leo72
Still not working... I changed a couple of pins, putting D0->A0, D1->A1, D12->A2 and D13->D12 but still not work.
The analog pins can be both input and output, isn't it?
I use to configure them as follow:
#define example_pin A0
pinMode(example_pin, OUTPUT);
Is it correct?
This is the code I'm testing right now:
Code: [Select]
#include <EEPROM.h>
//1st and 2nd 595
#define data1pin A0 //pin DS
#define latch1pin A1 //pin ST_CP
//3rd chip 595
#define data2pin 7 //pin DS
#define latch2pin 8 //pin ST_CP
#define clock2pin 9 //pin SH_CP
#define outputEnable 10 //pin OE/
//SRAM Chip
#define ram_we 3 //pin WE/
#define ram_ce2 4 //pin CE2
#define ram_oe 5 //pin OE/
#define ram_ce1 6 //pin CE1/
//chip 165
#define load_data A2 //pin Q7
/* SRAM
TO WRITE:
CE1/ -> LOW
WE/ -> LOW
CE2 -> HIGH
OE/ -> LOW
TO READ:
WE/ -> HIGH
CE1/ -> LOW
OE/ -> LOW
CE2 -> HIGH
    switch (stato) {
        case DISABLE:
        case WRITE:
        case READ:
    //initial pin setup
    //pinMode(master_reset, OUTPUT);
    //RAM pins: OUTPUT
    //S/r 165
    pinMode(outputEnable, OUTPUT);
    //initialize
        valore += 3;
        EEPROM.write(indirizzo, valore);
        delay(10);
    for (indirizzo = 0; indirizzo < 10; indirizzo++) {
        EEPROM.write(indirizzo+10, valore);
        delay(10);
    delay(5000);
    //delay
    byte hbyte, lbyte;
    digitalWrite(set_load, HIGH); // put the 165 pins in H.I. to prevent short circuits on the data bus
    digitalWrite(outputEnable, LOW); //wake up the 3rd 595
    digitalWrite(clock1pin, LOW);
    digitalWrite(clock2pin, LOW);
    shiftOut(data1pin, clock1pin, LSBFIRST, hbyte);
    shiftOut(data1pin, clock1pin, LSBFIRST, lbyte);
    shiftOut(data2pin, clock2pin, LSBFIRST, valore);
    set_ram(WRITE);
    delay(10);
    set_ram(DISABLE);
    digitalWrite(outputEnable, HIGH);
    //write the address
    digitalWrite(outputEnable, HIGH); //deselect the 3rd 595, so its output pins go into H.I. state
    set_ram(READ);
    delayMicroseconds(50);
    set_ram(DISABLE);
    return valore;
Grumpy_Mike
Quote
Is it correct?
No
#define example_pin 14
leo72
Ah... but in this thread you said the opposite thing  XD:
Quote
Under version 20 and beyond A0 is a predefined constant.
Grumpy_Mike
Yes but it is predefined as zero not as 14 which is what you want for using an analogue pin as a digital one.
So
val = analogRead(A0); // is fine but
val = digitalRead(A0); is the same as val = digitalRead(0);
leo72
Nothing changed.... I'm bored...  :smiley-roll: uff...
I'm starting to think that what I want to do is the classic "mission impossible".... is it possible to drive a parallel RAM with the peripherical chips I chose?
Grumpy_Mike
Quote
Yes it is. Do you have a scope so you can see if you are waggling the wires correctly?
leo72
No, I don't.
I think I will have di de-wire all the chips and start wiring up again from scratch.
One thing that I noticed is that if I disconnect the Vcc/GND wires from the Arduino board, the power LED that I've put on the breadboard still has a faint light, as in the circuit some current is still running, maybe from the output pins of the Arduino.... I don't know if it's normal...
I know that putting a pin of the Arduino in OUTPUT state should generate a low current: maybe with 14 pins connected to the circuit some sort of parasite current is still running through the wires... don't know...  ^_^
This night I will have some time to check the circuit. Stay tuned...  ;)
Grumpy_Mike
Don't forget to include decoupling capacitors, it won't work without them.
Quote
This implies you have disconnected power and ground but left the signal wires going into the chips. That is a good way to kill them. Never put a signal into an unpowerd chip.
ccfreak2k
It's entirely possible to drive parallel chips with shift registers, but on MCUs with SPI/I2C hardware (or software) it's not as practical since SRAM chips are also manufactured with built-in SPI/I2C hardware.
leo72
:smiley-roll-blue:
