Loading...
Pages: [1]   Go Down
Author Topic: Good transistors for making stepper motor driver  (Read 2558 times)
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
I have some big, 1.5A, 5-phase stepper motors and I need 10 transistors each to make a stepper driver for them. What kind of transistor do I need for a high-power switching application like this? And hopefully not too expensive.
Logged
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
Well, I guess I have to figure out how to drive the damn thing first. There are only 5 wires...red, green, blue, black, and orange. I'm not sure if I need H-bridges or half-bridges or what.
Logged
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
Ok this is the circuit I found.
I think those transistor pairs are called half-bridges.
So, will those PNP and NPN BJTs be fast enough to switch at like 10kHz directly off a microcontroller (50kHz is needed for 60rpm on this motor)? These vexta steppers are all over the place in semiconductor mfg equipment but such a pain. Compared to normal steppers.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hope these help.
http://arduino.cc/en/Tutorial/MotorKnob
http://www.tigoe.net/pcomp/code/circuits/motors/stepper-motors
Logged
St. Louis, Missouri
Offline Offline
Sr. Member
Arduino rocks
View Profile
Take a look here: http://www.cs.uiowa.edu/~jones/step/. Jones seems to be the defacto stepper authority on the internet. A link to his site should probably be included somewhere in the Arduino site.
Logged
Seattle WA
Offline Offline
Full Member
Arduino rocks
View Profile
WWW
You need a half-bridge on each. See the Jones link someone else provided for more on how to drive it -- five phase motors are kind of weird.
Logged
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
I'm pretty sure the circuit I posted above is what I need to drive it, but I'm not sure if the picture will show up if you aren't signed in. I'm just worried I won't be able to switch the transistors at 50+kHz, or that the motor won't work properly at that speed without a proper 'chopper' drive system.
Logged
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
I'm "obsessing" on 50kHz because that is how fast I will have to step the motor for my application, as I said clearly:
Quote
The motor is .0072 degrees per step, so I need to step it at 50kHz to get 60RPM. I'm not sure if I will be able to do this with a simple switching controller so it's a real concern for me. I said nothing about PWM at any point; you came up with that out of the blue.
« Last Edit: February 02, 2011, 10:41:31 am by BetterSense » Logged
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
There is a label on the side of it that states "5-phase stepping motor, 1.4A, .0072deg/step".
Logged
Dallas
Offline Offline
Sr. Member
nephew as a kittens
View Profile
Quote
What kind of motor is this?
Vexta. Grey.
Quote
Where did it come from?
The robot on an AMAT RTP tool. An industrial robot.
Quote
Is this some sort of specialty motor?
Apparently, since it's impossible to find cheap driver ICs for 5-phase stepping motors.
Quote
Is it really .0072 deg/step without microstepping?
I think it's .72 degrees, but it has an integral 100:1 gearbox. There appears to be no way to remove the gearbox.
Quote
How you you know it will do 50 KHz?
I don't.
Quote
That also seems extraordinarily unlikely
Lame. I wanted to make an RC lawnmower. I want at least 2 m/s. With 30cm wheels, I need about 60RPM. I was going to make a driver with 10 transistors and an ATtiny, but maybe I should forget the whole thing.
Logged
Pages: [1]   Go Up
Print
Jump to:
