Topic: switching diode help (Read 1 time) previous topic - next topic
KawasakiZx10r
Hello i have been trying t reverse engineer a EC sensor pcb for the past week and i am stuck on just one part being the switching diodes. with a magnifying glass i see ST 41 printed on the glass diodes but nothing more, so i when out and bought some 1n4148 switching diodes, they the pcb does not work so today i got some ST 41 48  diodes from ebay with no specs and now i get a reading on my arduino of 0.65 using
Code: [Select]
ecValue = analogRead(1) * 5.00 / 1024, 2; but it does not change, this is progress as with the 1n4`48,s i was getting 0 all the time. before you ask yes the polarity of the diodes is correct on my pcb, So my question is who many different types of 41 version switching diodes are there ? what do you think is wrong the forwarding voltage or amps of the diode? Is there any way i can test the diodes on the WAI pcb to find their specs ?
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
Isaac96
The diodes may be Zeners?
The best way to figure out which type the diode are is to test them for maximum ratings with a welder.  :smiley-twist:
You could measure voltage drop etc. but there is not much else you can do. (IMHO)
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
KawasakiZx10r
i tested the voltage drop with a digital multimeter in diode mode and both the St 41 48 diodes im using and the St 41 diodes on the other pcb both get 0.6 in both directions - polarity ? is that any help identifying them?
Albert Einstein
Isaac96
I cannot identify diodes given the voltage drop  :o
Some others on this forum probably have the required skillset?
@Robin2 possibly
Please upload pictures so we can see the exact part.
Thanks
Grumpy_Mike
All the voltage drop tells you is the material it is made from, in this case silicon. But if you measure the same in both directions you do not have a diode. Maybe your measurement technique is wrong. How are you doing it?
Wawa
Google tells me that an ST41 is a 3.3volt stabistor diode, whatever that is.
Type of low voltage more accurate and sharper cutoff zener, used for voltage clamping and input pin protection.
Not sure if a 3.3volt standoff TVS diode is the same.
Leo..
KawasakiZx10r
yay i got it working i had a micro break in a connection on my pcb i etched. im happy now i had spent a while on it and i was worried i had done something else wrong. Thank you all for the help.
Albert Einstein
