Topic: Upload failed to Arduino Mega 2560 via Bluetooth (Read 1 time) previous topic - next topic
srinadhpotnuru
After trying to upload sketch to Arduino Mega from HC-05 as shown at this link (https://www.instructables.com/id/Program-an-Arduino-Wireless-Over-Bluetooth/) the upload keeps failing. But the same circuit works fine with Arduino Uno. Can anyone point me in the correct direction or identify the fault.
Bluetooth Module used - HC-05
Upload speed of board selected as 57600bps and Bluetooth module's baud rate set as 57600bps
Isaac96
Doesn't the Mega have an upload speed of 115200 bps? As does the Uno?
Please post the exact error message. Thank you.
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
srinadhpotnuru
The upload speed of both have been changed to 57600 to match with HC-05's baud rate. Errors displayed
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
Isaac96
Is the Mega resetting properly upon upload?
Can you upload to the Mega without the Bluetooth et al?
srinadhpotnuru
The upload with USB is successful and the reset on upload from bluetooth is failing
Isaac96
#5
Oct 21, 2017, 04:53 pm Last Edit: Oct 21, 2017, 04:53 pm by Isaac96
The reset on upload? That would be in the domain of the Instructable. Looking at the Mega and Uno schematics, the reset circuits are apparently identical.
srinadhpotnuru
Apparently the Mega circuit has a 22pF capacitor between Reset and ground. Would this be affecting anything? Can you point me in the right direction to identify the reset characteristics and requirements for a program upload to Arduino boards from Serial.
Isaac96
Usually the pulse to 0V resets any Arduino. The reset circuits seem to be identical with the Uno and Mega, so what works for the Uno should work for the Mega. Does the exact same setup work on an Uno? And did you burn new bootloaders to the boards to work with the 57600baud upload speed?
Note: you can actually make the BT module work at 115200.
Michel1988
Hey all, I have exactly the same problem. Upload on UNO with same circuit goes fine but upload on Mega fails. Could you post your solution? Thx
thewhite
I am using the circuit from https://makezine.com/projects/diy-arduino-bluetooth-programming-shield/ STEP 8.
It works well for me with HC-05 and Arduino Mega.
In addition I've added a diode between HC-05 tx and resistor. Katode to HC-05. With that diode I can upload both ways : wireless and usb. It works on 115200bps
