Topic: Transmit GPS information wirelessly using UNO and (2) Xbee's S1 (Read 3085 times) previous topic - next topic
GianniSA
Good evening all.
Been running into some issues for the past few days trying to transmit NMEA data using simple point-point communication on my Xbees. I have 1 Xbee connected to my laptop via Xbee Explorer(http://www.sparkfun.com/products/8687) as a receiver, and another xbee connected to my Arduino UNO via Xbee Shield (http://www.sparkfun.com/products/9588) as a transmitter. I have already proven wireless functionality with the PhysicalPixel sketch example.
Using the Parallax GPS module (http://www.parallax.com/tabid/768/ProductID/396/Default.aspx) I wanted to see the NMEA strings serially, so I modded the Seral.Read example found on the Arduino website. On the GPS Module itself, I have /RAW GND tied to groun on the UNO, VCC supplied with+5V, and SIO in Pin0RX.
Code: [Select]
int incomingByte = 0;
Serial.begin(4800);
if (Serial.available() > 0) {
incomingByte = Serial.read();
Serial.print(incomingByte, BYTE);
This is what I saw in the Serial Monitor:
$GPRMC,040022.035,V,0000.0000,N,00000.0000,E,,,150209,,,N*7B
$GPGGA,040023.035,0000.0000,N,00000.0000,E,0,00,,0.0,M,0.0,M,,0000*40
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
Which was expected. I powered my UNO with another computer, set the switch on the Xbee shield to UART, and observed the terminal X-CTU where my xbee explorer was plugged into and saw that only a segment of the NMEA string was transmitted (shown below)
After transmitting this data, communication between the explorer and UNO just hung up. I did a little research and found that since the GPS module is eating up my TX and RX pin so much that I can't transmit this information wirelessly ( is this a correct assumption?)
This is my flowchart interpretation of whats going on:
With this in mind, I decided to control the power of the GPS module by controlling the VCC input with a digital pin. I figured since the GPS never stops receiving information, I could temporarily turn off the GPS after receiving the NMEA strings, store the NMEA strings, serially write them (wireless when switched to UART) to my computer. But still no success. I am pretty much at an ends as to what I can do to get this information to transmit wirelessly. I have looked into Newsoftserial, but I have a feeling that only helps for controllers with multiple TX and RX pins.
If any other information is needed, please let me know.
Thanks,
GA
PaulS
Quote
No, the assumption is incorrect. You can have only ONE device on either ends of a serial port - either the PC or the GPS. Not both.
Quote
Not surprising. Turning off the GPS requires that it find satellites again every time you turn it on. And, you still have it connected to the hardware serial port, which won't work.
Quote
No, the whole purpose of NewSoftSerial is to create software serial ports on devices that have only one hardware serial port. You DO need to use NewSoftSerial to read the GPS.
NewSoftSerial does, in fact, not play well with devices that do have more than 1 hardware serial port, which is fine because it is (generally) not needed on those devices.
GianniSA
Ok i'll do a little more research on the softserial. Although there is still something bothering me, why would this be a solution to my problem?  So the idea here is that the GPS information is interpreted by a digital pin that I specify. Why is leaving the rx pin unused beneficial to me. Any data transmitted is purely done by the TX pin, does this have to do with the fact that my system set-up is half duplex?
-GA
GianniSA
Hey Paul, I have attempted to use the Newsoftserial with not much success. I used a simple example from their library shown below...
Code: [Select]
#include <NewSoftSerial.h>
NewSoftSerial nss(2, 3);
NewSoftSerial nss2(4, 5);
 nss2.begin(4800);
 nss.begin(4800);
 // Every 10 seconds switch from
 // one serial GPS device to the other
 if ((millis() / 10000) % 2 == 0)
   if (nss.available())
     Serial.print(nss.read(), BYTE);
   if (nss2.available())
     Serial.print(nss2.read(), BYTE);
I am still not understanding why it would be beneficial to switch from one set of pins to another. GPS information can only be received through Pin RX on the arduino. The GPS receiver I have has only one dedicated pin for transmitting and receiving (the parallax one i linked earlier) maybe you can shed some light on some missing concepts here...
Quote
ARG i'm still not understanding what you mean by this. So if the RX pin is being used by the GPS receiver, the TX pin cannot be used to talk to the computer at the same time? Should I buy a GPS with separate TX and RX pin? What is a better approach to just trying to implement complicated software? Any help would be appreciated as I am completely brain dead and lost as I have been working on this ever since I replied.
-GA
PaulS
Quote
This is the heart of your problem. The GPS data can be received by ANY digital pin on the Arduino, if you use NewSoftSerial.
Quote
There is even a simpler example that uses ONE instance of NewSoftSerial. That is the basis for your application.
Quote
You should not think of the TX and RX pins as independent. They form a pair that is expected to be connected to ONE device. You wouldn't wear one hiking boot and one sandal, would you. Shoes come in pairs. TX/RX pins come in pairs.
GianniSA
Quote
I am still not seeing eye-eye on this.... Am I doing something wrong here?
Code: [Select]
  nss2.begin(4800);
  nss.begin(4800);
I have the SIO pin on the GPS module attached to digital pin 2 on the uno. Still no data seen through the terminal.
GianniSA
