Topic: Infrared Sensor (Read 5968 times) previous topic - next topic
baum
I got this IR Detector:
http://www.sparkfun.com/products/10266
from sparkfun.
I hooked up an LED to the output, and it blinks when I press a button a remote. But when I plug the output into the Arduino, nothing.
Help please!
(my hookup is simple: 5V to Vcc, GND to GND, Vout to pin 2.
DCContrarian
The output should be a series of digital pulses.
Grumpy_Mike
And what software? And what are you expecting it to do?
baum
I am expecting it to read a string of ones and zeroes when I press a button on an infrared remote. But I get nothing. Why would it work with the LED, but not on the arduino?
I am following ladyada's tutorial at
http://www.ladyada.net/learn/sensors/ir.html
Look at her diagrams. The first one (with the LED) works. But the next one, exactly how she has it (with the arduino) does not work. I am using her code.
Grumpy_Mike
So you need to see where it is going wrong.
1) Just write a simple program that looks at the digital input pin and lights up the LED on pin 13 depending the input state. That will tell you if the hardware is wired up correctly.
2) If that works then put some print statements in the code and see where it is getting stuck.
The results of these two tests will point you in the right direction.
baum
I am using the example digital read serial under the examples folder. The program works if I, say, wire up a button. But not with the ir sensor. It just stays at 0 (at least it's tied to ground!)
Could serial comm. be too slow for the sensor to read the pulses? (but why won't ladyada's optimized program work?)
Odd.
Also... If there is NO ir light, should the sensor be off, or sort of off? Mine says 1.5 V w/ a 5V source if no ir light is being turned on.
I hope it's not broken... I haven't done anything to it!
baum
It's broken. datasheet from vishay (see above link) says MAX low output is 100mV.
Grumpy_Mike
Quote
That doesn't sound good. It should be zero volts with no light.
It is a modulated light receiver so it won't be affected by stray light. The data sheet (and my experience) says they are very sensitive to power supply ripple. It recommends a 100R series resistor and a 4u7F capacitor on the power line. If you are lucky the small voltage you see is the chip oscillating, if not it has broken.
baum
But I am setting it up exactly as ladyada has it, and she has no problems!
It's being powered by arduino's 5V, too, so its probably regulated enough, no?
Grumpy_Mike
Quote
That is the problem with the internet, just because someone tries something once and has no problems doesn't mean it is a good robust repeatable design.
Quote
No - decoupling is little to do with regulation, it is to do with interference on the power line, causing interference to the device. A company I used to work for made the same mistake of not decoupling this very part. It went all through the development process and testing and it wasn't until they had built several thousand boxes that it came to light that a significant number of IR detectors failed through lack of decoupling.
baum
If I add a cap now as vishay says, can i get the sensor to work? or is it dead? :( :((
Grumpy_Mike
I don't know.
It's not just the cap but the resistor as well. It's worth a try.
baum
k.
Thinking back on it, when I was testing the voltage with my multimeter, I may have shorted the GND and out pins. Would that do anything?
Grumpy_Mike
Well if the block diagram in the data sheet is to be believed then no that would not damage it.
baum
But why such a high low voltage? And why nothing on the arduino?
(Then I aimed a remote at the IR sensor, with the multimeter on, and I the voltage droppe by about 100mV, but it worked, sort of, with the LED.)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
