Topic: My Perfboarduino (Read 2675 times) previous topic - next topic
jezuz
I put together a perfboard arduino clone from left over parts of old projects. Check it out over at my blog (I need hits  8) )
http://www.rustechstudio.com/big-builds/perfboarduino/
cr0sh
Not bad; better hope your ATMega doesn't blow, or you have some work ahead of ya! Might be easier to route those lines on the bottom or something... :)
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
jezuz
Good point. They also get in the way of the soldering on the bottom of some shields. I might just rip them up next time the atmega does blow (because it's inevitable).
cr0sh
The other thing I noticed was that you have parts on each end of the DIP socket that would seem to making pulling the IC a difficult proposition without a DIP extractor (I'm not even sure they still sell them?). At least, if you used the "screwdriver on each end" technique to pop the chip, doing so would take some patience to avoid damaging those components on the extreme ends...
jezuz
To be honest my main objective was stuffing in as much as possible without thinking about leaving proper spacing.
retrolefty
Quote
Note to even mention the red and green wires that loop over the top of the chip.  XD
Hey, no sweat. You built it, it works, you learned a lot. That's what Arduino building is all about. Next time you will do it a little different just because it's the next time.  :D
Lefty
