Topic: EasyDriver v4.3 and sparkfun Stepper motor woes (Read 8376 times) previous topic - next topic
pingy
Changed enable to LOW
switched the speed to 10.0
and still NOTHING!
The motor stays fully engaged and does not spin at all!
Arduino v 0022
Thanks for sticking through this with me man....any other ideas?
pingy
I just wired everything up on my duemilanove just in case there was something funny going on with my new UNO board as I have never used it for anything before.
Still no good. Same results.
pingy
Just unplugged the motor from the EasyDriver and hooked it back up directly to my Duemilanove and ran some example code and that works fine.
Im still pointing fingers at either the EasyDriver or AC wall wart.
41south
This may be a silly question - but is your wallwart outputting 12v DC or 12V AC? I know I've got a few at home that are AC output, it's caught me once or twice. 8)
If it is DC can you check the volts with a multimeter when it's trying to run the motors to see if maybe it's dying under load?
pingy
mmcp42
#20
Feb 06, 2011, 02:55 pm Last Edit: Feb 06, 2011, 02:57 pm by mmcp42 Reason: 1
ok
why not post the "code-that-works"
are you driving it direct from the Arduino - that's "unusual"
wouldn't have thought it had the power
might also be worth trying with IDE 21 if you can
I'm sure I have something at the back of my mind (but it's very dark in there)
there are only 10 types of people
them that understands binary
and them that doesn't
pingy
The code that works is the sample stepper code with the motor pins directly in the Arduino.
Sorry I'm on my phone. I'll post more later
arroth999
I had the same exact problem.  Did you ever figure it out?  My motor works when directly attached to the Arduino, running the example code from Schmalzhous...Thanks!
Austin
abdelmoneam
how many wires does your motor have(is it uni polar or bipolar motor)?
cuz if it uni-polar it will not work with the driver it has to be bipolar
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
