Pages: [1]   Go Down
Author Topic: Shiftbrite and Wifly Shield SPI help  (Read 1045 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Hello all,
             I have some shiftbrite's that I have working, I have written lots of little code snippets to do different things with them.  So I had the idea instead of controlling them through a laptop connected with a USB cable I would like to control them through any web browser through wifi.  I just received the wifly from sparkfun and already I am thinking my idea might not work.  The wifly shield communicates through SPI as do the shiftbrites.  Is this possible for this to work or will I have to find another solution?  I noticed the ethernet shield also communicates through SPI as well so I imagine it is the same story.  I can use two arduino's set up as master slave, but I would really like to do this wirelessly through a browser.  Any help is greatly appreciated.
Logged
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
There is an example on the documentation site for controlling Shiftbrites without using the hardware SPI pins: http://docs.macetech.com/doku.php/non-hardware_spi_example
You can select any available pins. It will be somewhat slower than the SPI code, and means that you cannot use a ShiftBrite Shield, but will not interfere with the WiFly or other shields that use SPI.
Logged
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Thanks again Mace
Logged
Pages: [1]   Go Up
Jump to:
