Topic: [Q] Library functions help (Read 903 times) previous topic - next topic
hello,i'm hoping for some guidance.
I'm trying to write a library to interface with the HMC6343 sensor and in short, no matter what i seem to do, i get massive amounts of errors and i'm hoping for some help.
without further ado,
Code: [Select]
//arduino
#include <Wire.h>
#include <sensor.h>
int heading;
int pitch;
int roll;
int H[3];
void setup(){
 Serial.begin(9600);   //set up serial baud rate
 Wire.begin();
void loop(){
 H[3]=sensor.getHeading();
 Serial.print("Heading: x: ");
 Serial.print(H[0], DEC);
 Serial.print(" y: ");
 Serial.print(H[1], DEC);
 Serial.print(" z: ");
 Serial.print(H[2], DEC);
 delay(5000);
Code: [Select]
//sensor.cpp
#include <WProgram.h>
#include <sensor.h>
#include <Wire.h>
#define compassAddress 0x32>>1        //I2C slave address from datasheet
int[3] sensor::getHeading() {
 Wire.beginTransmission(compassAddress);
 Wire.send(0x50);                    //send getHeading command to sensor
 Wire.endTransmission();
 delay(2);                           //pause for sensor to read data
 Wire.requestFrom(compassAddress,6);  //request six bits of data from sensor
 for(int i=0; i<6; i++) {
   while(Wire.available()==0);
   _data[i] = Wire.receive();        //write recieved data to data[]
 H={(_data[0]*256 + _data[1])/10, _data[2]*256 + _data[3], _data[4]*256 + _data[5]}     //scale heading variable
 return H;
Code: [Select]
//sensor.h
#ifndef sensor_h
#define sensor_h
#include <Wire.h>
class sensor
public:
    //heading variables
   int H[3];
    //heading functions
   int getHeading();
private:
   byte _data[6];
#endif
this is just controlling the heading variables. I keep getting errors "expected primary-expression before '.' token" at the function call" in the arduino code. I also wanted to use pointers to output the three variables separately rather than the ugly H[3] array, but it was more trouble than i had anticipated. Any guidance would be much appreciated. Thanks!!
AlphaBeta
you can not return an array as it will be destroyed by the stack
you should do as you first thought like this:
Code: [Select]
//in header
public:
void getHeading(int &x, int &y, int &z);
//in cpp
void sensor::getHeading(int &x, int &y, int &z) {
  x = (_data[0]*256 + _data[1])/10;
  y = _data[2]*256 + _data[3];
  z = _data[4]*256 + _data[5];    //scale heading variable
  //x, y and z will be changed at the scope outside this method
Thank you so much for the quick reply AlphaBeta!
The pointers have been added as you said, but i'mstill having trouble accessing the functions withing the sensor class for some reason. When i compile i'm getting
Quote
sketch_feb01a.cpp: In function 'void loop()':
sketch_feb01a:44: error: expected unqualified-id before '.' token
and line 44 is void loop() { so i'm assuming it has more to do with the function call at void sensor.getHeading(&x,&y,&z); as it is written now.
Any ideas on why this is? Is my syntax incorrect in the library or the class? i can reprint the code as it is written now if it might help someone smarter than i am help me solve this issue
thanks again!
AlphaBeta
Create an instance of class sensor like this: sensor mySensor; then call the getHeading like this: mySensor.getHeading(x,y,z); //assumes x y and z already exists and that they are declared as ints
#4
Feb 02, 2011, 10:53 pm Last Edit: Feb 02, 2011, 11:16 pm by sammydadams Reason: 1
EDIT::
It seems to be working!!! I thought it wasnt but it turns out that one of the I2C wires was loose!!
thanks Alpha!
#5
Feb 04, 2011, 02:09 am Last Edit: Feb 04, 2011, 02:17 am by sammydadams Reason: 1
one final question is whether i can create the instance like AlphaBeta said, sensor mysensor; within the library...i only ask because i notice that you dont have to actively create an instance of libraries like wire or others. I looked through some other libraries and noticed things like:
Code: [Select]
// Constructors
TwoWire::TwoWire()
in Wire.cpp and a corresponding
Code: [Select]
class TwoWire
 public:
   TwoWire();
in Wire.h
thinking this might be what i was looking for, i tried to implement it in my library, but it didnt work. The library in general is coming along nicely,however, and controlling my sensor like a champ with the sensor mysensor; in the arduino code, it just seems that there might be a way for the inclusion to take care of that as well.
This final question then i'm out of your hair on this issue, i promise!
thanks
AlphaBeta
Look at line 64 for the extern keyword?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
