Topic: Understanding Uno's FDN304 MOSFET (Read 5683 times) previous topic - next topic
Glacial_Wanderer
Feb 02, 2011, 01:45 pm Last Edit: Feb 02, 2011, 03:31 pm by GlacialWanderer Reason: 1
Perhaps this is more of a general mosfet question.  I'm trying to understand how this and mosfets work in general so I can select one for another project.
If I look at Uno's schematic (http://arduino.cc/en/uploads/Main/arduino-uno-schematic.pdf) it appears this mosfet is ON with 0 V at the gate since the op amp is used as a comparator and it makes sense to use USB power when the external power is < 3.3V.  However, when I look at the data sheet for the FDN304 (http://www.fairchildsemi.com/ds/FD/FDN304PZ.pdf) the graphs seem to show drain current as 0 and a high drain resistance for 0V at the gate (ie off).  I'm a little confused why everything is marked as negative on those graphs so maybe someone who understands those graphs can explain them.  My understanding is that most mosfets are enhanced mode and those are off with 0 gate voltage.  Depletion mode mosfets are on by default and what I want.  The datasheet for FDN304 doesn't say what kind of mosfet it is, but it has the standard enhanced mode mosfet symbol in the datasheet.  So my observation is that the Uno circuit seems to say it's on with 0V at gate, but the data sheet graphs/symbol says it's off with 0V at the gate.  I'm not 100% sure about either one so I'm not sure where my mistake is.
What I want to do is turn off battery power when USB is connected to my device.  To me I either need an enhanced mode mosfet with an inverter to make the switch to the batter off when there is 5V on USB, or I need a depletion mode transistor with no inverter.  The problem is depletion mode transistors seem to be fairly low current and I need something around 750mA at a 2V.
Summary:  Can anyone explain why the UNO's seemly enhanced mode MOSFET seems to be working as a depletion mode mosfet in that circuit?  And do you have any suggestions on how to best turn off battery power when USB is connected to a device?
Thanks!
[Edited to fix typos]
pwillard
#1
Feb 02, 2011, 02:17 pm Last Edit: Feb 02, 2011, 02:19 pm by pwillard Reason: 1
My understanding is the reverse of yours... but I'm not a big mosfet user:
Quote
My understanding is that most mosfets are enhanced mode and those are on with 0 gate voltage.
To me... an enhancement device is normally "OFF" when the gate bias voltage is equal to zero and turns on otherwise.
Glacial_Wanderer
pwillard, that was a typo and I've fixed it in my post.
Grumpy_Mike
#3
Feb 02, 2011, 04:45 pm Last Edit: Feb 02, 2011, 04:47 pm by Grumpy_Mike Reason: 1
The FDN304 is a P channel FET. This means to turn it on you have to put the gate to 0v, or make it more negative than the source by the turn on voltage.
It is rather like the FET equivalent of a PNP transistor. This is sometimes best understood with the term "upside down transistor". You use P channel FETs  for top switching, that is sourcing current rather than sinking current. That is why the data sheet has all the negative signs.
A data sheet that says what sort of FET it is can be found here:-
http://www.fairchildsemi.com/ds/FD/FDN304P.pdf
Glacial_Wanderer
Thanks that was helpful!
I remember reading the that the gate on a MOSFET has a large internal resistance so there is no need to put something like a 10K resistor between the voltage source and the gate to limit current.  Is that correct?  Bonus points if you can tell me what on the datasheet gives me this info.
retrolefty
#5
Feb 02, 2011, 08:32 pm Last Edit: Feb 02, 2011, 08:34 pm by retrolefty Reason: 1
Not resistance but rather high gate capacitance causing higher current draw when switching gate voltage on or off. Once fully charged or discharged a mosfet gate draws zero current. Any mosfet datasheet will show device capacitance value. One trade-off is that any series gate resistor will slow down the switching transition time from off to on or on to off, due to the RC time constant, causing the device to be in it's 'linear' mode longer and causing more device power dissipation (heat);
Lefty
Glacial_Wanderer
Lefty
Most of what you said made sense.  I was confused by "trade-off".  You didn't explain the positive side of use a series resistor to the gate of a fet.  Is is just that it's required to keep peak current down?  And is there generally a good sized resistor people tend to use in general cases (100, 1k, 10K)?
Thanks!
ollybutterfield
Hi
I'm also trying to understand the power system on the Uno, and as it's very closely related to what's being discussed here, I thought I'd tag it on here. Could somebody tell me whether my following ramblings are correct or not please?
USB provides a regulated 5v source, so if this is the only power connected, the gate of the FDN304 is 0v and USBVCC passes through and becomes the 5v rail. The op amp is using a 50:50 voltage divider to compare Vin from the external source to the regulated 3.3v source. Once Vin hits 6.6v (and the op amp sees 3.3v on this pin) the output is switched on, producing 5v at the gate of the FDN304, meaning the USBVCC is "switched off". This allows Vin, having passed through regulation, to become the 5v power source. But why are there two of the MC33239 chips? I just can't get my head round that bit of the circuit  :~
Thanks!
Olly
retrolefty
Quote
Yes, a series resistor is to limit the peak current the voltage driving source has to provide to charge or discharge the gate capacitance. As an Arduino output pin has a absolute maximum current rating of 40 ma then a 125 ohm or higher series resistor will prevent the gate current draw from exceeding that safety rating.
The tradeoff is again any series resistor will cause a RC time constant delay the will 'slow down' the transition time between fully on and fully off or fully off to fully on for the mosfet source/drain current path. This may not be a big deal if the mosfet is switching a current load well below it's maximum rated capacity and/or is heatsinked well.
For very high voltage/current mosfet devices many advice using special gate driver ICs that can provide several amps of gate current drive, thus keeping the mosfets heat dissipation to a minimum possible by having the fastest possible switching time.
Lefty
Grumpy_Mike
Quote
You need two in the schematic to give two footprints on the PCB. These two footprints a different for different types of regulator, if you look at the schematic you will see one is MC33269ST-5.0T3 and the other is MC33269D-5.0. In practice only one of theses regulators is fitted, it gives the factory a choice of components to use if one gets to be in short supply.
Glacial_Wanderer
Thanks for answering all my questions.  You folks are awesome!
ollybutterfield
Thanks Mike, that makes me a lot happier!
Glacial_Wanderer
I ordered a few of these (http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDN304PZ/?qs=sGAEpiMZZMv4eh0jmGe023MliyXefJywkNxtsL75n1Q%3d) to test out and they aren't working as I expected from the discussion above.
My test circuit it very simple.  I have 5V attached to the drain.  I have a 470K ohm resistor, an LED, and ground attached to the source.  I have a 1k resistor attached to the gate and then connect that to either 5V or Gnd expecting it to switch on/off the LED, but it doesn't.  The LED is always on.
Does anyone know why this part isn't acting as a switch like I expected it to?
pwillard
Glacial_Wanderer
The problem with my original circuit was that the source and drain were switched.  Thanks!
