Topic: Convert string to long integer on Arduino (Read 31501 times) previous topic - next topic
cgifford
I need to convert a string to a long integer on the Arduino.
For example:
I want to convert the string "1600" to an integer equal to 1600.
How could I do that in C++ in the Arduino?
Although I know its not correct, I tried something like the following: intDist2Move = int(strDist2Move);
Of course, that did not work but you can see where I am going with it.
Thanks for the help.
Coby.
Graynomad
Rob Gray aka the GRAYnomad www.robgray.com
cgifford
Rob,
Thanks for your help.
I tried your suggestion and did get an error.
Perhaps, it has something to do with the way I am declaring it in the beginning?
I am still a rookie with C++.
Here is my code:
// Declaration of string
String strSteps = String();
strSteps = "1600";
long steps2move = atol(strSteps);
Here is the error I get:
error: cannot convert 'String' to 'const char*' for argument '1' to 'long int atol(const char*)'
Thanks, again.
Coby.
ccfreak2k
atol() and kin cannot take String. They need null-terminated character strings.
cgifford
Thanks, I am making a little headway, but I am stuck again.
Here's my entire code:
Compiler stops at "charSteps[ ] = strSteps;" with the following error:
expected primary-expression before ']' token
Code: [Select]
int dirPin = 4;
int stepperPin= 3;
int sleepPin=7;
String strSteps = "";
char charSteps[] = "";
#define INLENGTH 16
#define INTERMINATOR 13
char inString[INLENGTH+1];
int inCount;
long steps2move;
boolean blnDir2move;
void setup () {
pinMode (dirPin, OUTPUT);
pinMode (stepperPin, OUTPUT);
pinMode(sleepPin,OUTPUT);
Serial.flush();
// Wire Connections --------------------------------
// 4-Wire From Motor (CA/XX & CB/YY)
// Arduino o3 to Step @ EasyDriver
// Arduino o4 to Dir @ EasyDriver
// Arduino o7 to Sleep @ EasyDriver
// Gnd&Pwr @ EasyDriver to Battery -/+ Respectively
// Software Logic ----------------------------------
// Arduino o3 & o4 are the only items needed to interact with
// Send serial message
//void loop() {
////step(false,160);
////delay(500);
//  if (Serial.available() > 0) {
//    delay(25);
  if (Serial.available() > 0){
      delay(75);
      inCount = 0;
      do {
        inString[inCount] = Serial.read();       // get it
        if (inString [inCount] == INTERMINATOR) break;{
          (++inCount < INLENGTH);
          inString[inCount] = 0;  // null terminate the string
      while (Serial.available());             // wait for input
      if (inString[0] == '0') { // TURRET MOVE COMMAND
           steps2move = 0;
           for (int i=2;i < inCount;i++){
               strSteps += char(inString[i]);
           long steps2move = atol(charSteps);
            if (inString[1] == '0'){
              blnDir2move = true;
            else{
              blnDir2move = false;
            Serial.println(blnDir2move);
           step(blnDir2move,100);
      Serial.flush();
void step(boolean dir,int steps){
digitalWrite(sleepPin,HIGH);
digitalWrite(dirPin,dir);
//delay(50);
  for(int i=0;i < steps;i++){
  digitalWrite(stepperPin, LOW);
  digitalWrite(stepperPin, HIGH);
  delayMicroseconds(3000);
digitalWrite(sleepPin,LOW);
cgifford
Thanks Rob!
Your input got me pointed in the right direction and I have now fixed my problem and moved on.
Used char type: charSteps
  • I filled the char with a loop, then assigned it using atol as you said.
    Here is my final code posted if anyone needs the same example:
    Code: [Select]
    #define FLXSTR 16
    #define INLENGTH 16
    int dirPin = 4;
    int stepperPin= 3;
    int sleepPin=7;
    char charSteps[FLXSTR];
    int inCount;
    long steps2move;
    void setup () {
    Serial.flush();
    //void loop() {
    ////delay(500);
    //    delay(25);
          delay(75);
          inCount = 0;
          do {
               steps2move = 0;
               int x = 0;
                   charSteps[x] = char(inString[i]);
                   x += 1;
                  blnDir2move = true;
                else{
               step(blnDir2move,steps2move);
          Serial.flush();
    //delay(50);
    Serial.print(1); //Confirm Move Completed
    delay(50);
Paul Stoffregen
Why not just use the toInt function, like this?
strSteps = "1600";
long steps2move = strSteps.toInt();
Also, if you're using the string objects, you might want to copy these 3 files into your hardware/arduino/cores/arduino directory.  They fix many bugs in the string class.
http://code.google.com/p/arduino/issues/detail?id=468
Rocketboy
Here is an easier way, look up toCharArray
zhrs is the input string , [] is the array size (number of characters in string +1)
dhrs is the int output.
   char tarray[3];
   zhrs.toCharArray(tarray, sizeof(tarray));
   dhrs = atoi(tarray);
Rock
AdrikBroad
I want to know how Arduino handles floats as the ATmega ?And how to print the sensors to serial monitor?
PaulS
Quote
You want to explain this question a little better? And, perhaps explain the relevance to the thread you are posting in.
Quote
You can't. Sensors are hardware. They can't be printed. Unless you have a rep-rap machine.
Paul Stoffregen
Float numbers work fine.  How Arduino handles them is pretty much like any other number, just put a variable in your code and give it "float" type.
As for printing to the Serial Monitor, just use Serial.print() like you would with an int or any other variable.
How Arduino actually handles floats could be answered in terms Arduino core code, avr-libc library code, the build process as implemented by Compiler.java, internal gcc compiler details, numerical formats (mantissa, exponent, normalization, rounding strategies, etc), binary data representations, logic circuitry, transistor-level CMOS logic implementation, analog characteristics of digital logic circuitry, propagation of electrons and changes in their energy states, electric and magnetic fields, semiconductor material physics, sub-atomic particles, and as-yet-to-be-discovered scientific understanding of matter and energy (eg, "grand unified theory").  But if you're at a beginner level, where you're not sure how to print a float (exactly the same as any other type of variable), learning exactly how Arduino handles floats would only distract you from learning the most basic skills to simply make use of them in your sketch.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
