Topic: "was not declared in this scope" error (Read 5233 times) previous topic - next topic
jorpec
I'm trying to improve my R2D2 robot, by adding 2 ir sensors on the legs, the code worked fine before i added the legs sensors code, only when i added a second "if" for the legs sensors i got this error, the most strange for me is the error appears on the first "if" of the code that worked fine before i added the second "if",  I cant figure out what is wrong
Thanks in advance
Here the part of the code where the error appears
Code: [Select]
  if (distance <= 20){
    moveStop();
    delay(300);
    moveBackward();
    moveStop();
    delay(300);
    distanceRight = lookRight();
    delay(300);
    distanceLeft = lookLeft();
    delay(300);
    if (distance >= distanceLeft){
      turnRight();
      moveStop();
    else{
      turnLeft();
      moveStop();
  else{
    moveForward();
    distance = readPing();  << the program points to this line where the error is
And here the full code
Code: [Select]
#include <Servo.h>
// L298N motor control pins
const int LeftMotorForward = 3;
const int LeftMotorBackward = 11;
const int RightMotorForward = 5;
const int RightMotorBackward = 6;
#define sensor A0
boolean goesForward = false;
int distance = 100;
Servo servo_motor;
int sensorPin = 5;
int lightPin = 8;
const int beepPin =  12;// the number of the beep pin
int beepState = LOW;
unsigned long previousMillis = 0;
// constants won't change:
const long interval = 10000;
int IRleftpin = A4;
int IRleftemitter = 2;
int ambientIRleft;
int obstacleIRleft;
int valueleft[10];
int distanceleftleg;
int IRrightpin = A1;
int IRrightemitter = 9;
int ambientIRright;
int obstacleIRright;
int valueright[10];
int distancerightleg;
void setup(){
  pinMode(beepPin, OUTPUT);
  pinMode(RightMotorForward, OUTPUT);
  pinMode(LeftMotorForward, OUTPUT);
  pinMode(LeftMotorBackward, OUTPUT);
  pinMode(RightMotorBackward, OUTPUT);
  servo_motor.attach(13);
  servo_motor.write(115);
  delay(2000);
  delay(100);
  pinMode(IRleftemitter,OUTPUT);
  digitalWrite(IRleftemitter,LOW);
  pinMode(IRrightemitter,OUTPUT);
  digitalWrite(IRrightemitter,LOW);
void loop(){
  beeps();
  frontlights();
  distanceleftleg = readIRleft(5);       // calling the function that will read the distance and passing the "accuracy" to it
  distancerightleg = readIRright(5);       // calling the function that will read the distance and passing the "accuracy" to it
  int distanceRight = 0;
  int distanceLeft = 0;
  delay(50);
    moveStop();
    delay(300);
    moveBackward();
    moveStop();
    delay(300);
    delay(300);
    delay(300);
      turnRight();
      moveStop();
    else{
      turnLeft();
      moveStop();
  else{
    moveForward();
    distance = readPing();  [color=red]<< the part where is the error[/color]
  if ((distanceleftleg > 100) || (distancerightleg > 100)){
    moveStop();
    delay(300);
    moveBackward();
    moveStop();
    delay(300);
    distanceRight = readIRleft();
    delay(300);
    distanceLeft = readIRleft();
    delay(300);
    if (distancerightleg > distanceLeftleg){
      turnRight();
      moveStop();
    else{
      turnLeft();
      moveStop();
  else{
    moveForward();
int readPing(){
  delay(70);
  float volts = analogRead(sensor)*0.0048828125;  // value from sensor * (5/1024)
  int cm = 13*pow(volts, -1); // worked out from datasheet graph
  if (cm==0){
    cm=250;
  return cm;
int lookRight(){
    for (int i = 115; i > 50; i--)
    servo_motor.write(i);
    delay(10);
  int distance = readPing();
  delay(100);
      for (int i = 50; i < 115; i++)
    delay(10);
  return distance;
int lookLeft(){
      for (int i = 115; i < 170; i++)
    delay(10);
  delay(100);
      for (int i = 170; i > 115; i--)
    delay(10);
  return distance;
  delay(100);
void moveStop(){
  digitalWrite(RightMotorForward, LOW);
  digitalWrite(LeftMotorForward, LOW);
  digitalWrite(RightMotorBackward, LOW);
  digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
  if(!goesForward){
    goesForward=true;
    analogWrite(LeftMotorForward, 80);
    analogWrite(RightMotorForward, 90);
    analogWrite(LeftMotorBackward, 0);
    analogWrite(RightMotorBackward, 0);
void moveBackward(){
  goesForward=false;
  analogWrite(LeftMotorBackward, 80);
  analogWrite(RightMotorBackward, 90);
  analogWrite(LeftMotorForward, 0);
  analogWrite(RightMotorForward, 0);
void turnRight(){
  delay(850);
void turnLeft(){
  delay(850);
  digitalWrite(LeftMotorForward, 80);
  digitalWrite(RightMotorForward, 90);
  digitalWrite(LeftMotorBackward, 0);
  digitalWrite(RightMotorBackward, 0);
void beeps(){
  if (currentMillis - previousMillis >= interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    if (beepState == LOW) {
      beepState = HIGH;
      beepState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(beepPin, beepState);
void frontlights(){
  // Read the sensor pin
  int sensorValue = analogRead(sensorPin);
  // If light level is low is detected, switch light on
  if (sensorValue < 35){
    digitalWrite(lightPin, HIGH);
  // If light level goes up again, switch the lights off
  if (sensorValue > 150){
    digitalWrite(lightPin, LOW);
int readIRleft(int times){
  for(int x=0;x<times;x++){
    digitalWrite(IRleftemitter,LOW);           // turning the IR LEDs off to read the IR coming from the ambient
    delay(1);                                             // minimum delay necessary to read values
    ambientIRleft = analogRead(IRleftpin);  // storing IR coming from the ambient
    digitalWrite(IRleftemitter,HIGH);          // turning the IR LEDs on to read the IR coming from the obstacle
    obstacleIRleft = analogRead(IRleftpin);  // storing IR coming from the obstacle
    valueleft[x] = ambientIRleft-obstacleIRleft;   // calculating changes in IR values and storing it for future average
  for(int x=0;x<times;x++){        // calculating the average based on the "accuracy"
    distanceleftleg+=valueleft[x];
  return(distanceleftleg/times);            // return the final value
int readIRright(int times){
    digitalWrite(IRrightemitter,LOW);           // turning the IR LEDs off to read the IR coming from the ambient
    ambientIRright = analogRead(IRrightpin);  // storing IR coming from the ambient
    digitalWrite(IRrightemitter,HIGH);          // turning the IR LEDs on to read the IR coming from the obstacle
    obstacleIRright = analogRead(IRrightpin);  // storing IR coming from the obstacle
    valueright[x] = ambientIRright-obstacleIRright;   // calculating changes in IR values and storing it for future average
    distancerightleg+=valueright[x];
  return(distancerightleg/times);            // return the final value
wildbill
Get rid of the closing brace after that statement - it's telling the compiler that's the end of the loop function.
jorpec
Thanks
I guessed it was some sort of comma or brace missing or too much
