Loading...
Pages: 1 [2]   Go Down
Author Topic: What I learned today: Flux is awesome!  (Read 1313 times)
Chester, UK
Offline Offline
Sr. Member
Trying to return the love to none logic level MOSFETS
View Profile
An ink eraser is handy for clean pcb traces
Logged
If your system involves lethal voltages/life critical/flamable elements - you probably shouldn't need to ask.
The Arduino != PC.
Newcastle, England
Offline Offline
Sr. Member
Always learning!
View Profile
WWW
Quote
P.S. I won't start a whole new thread for this but also buy desoldering braid. It comes in very handy as well.
I prefer a de-solder pump. They are really quick and easy, and can clear large blobs almost immediately. And they are re-usable, so you do not have to keep buying more!
Logged
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) smiley-grin
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
Not useful for surface mount, though. Can't get a good seal to the edge of an IC and with some huge thing jumping around next to fragile pins you're going to break something.
Desoldering braid is definitely a must-have. When you need it, you NEED it.
Logged
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
Northern California (by San Francisco)
Offline Offline
Full Member
View Profile
Quote
That's probably true. If you do a lot of soldering, you should have some braid.
And I do have some braid. But I've never used it. Never needed it. I do, on the other hand, use my "solder sucker" bulb pretty much every time I solder. It's a very handy device. I would never solder without it.
I might mention, too, that I never have attempted to solder a surface mount device. Probably never will. As noted, I suspect braid would be much better for that.
Logged
SF Bay Area
Offline Offline
Edison Member
Arduino Ninja
View Profile
WWW
Right....I have never used desoldering braid on through hole parts either. I do grab the soldapult for those. It's not in the NEED zone, but most times is easier than whacking the PCB on the bench while melting the solder.
Logged
Seattle WA
Offline Offline
Full Member
Arduino rocks
View Profile
WWW
One note about the water-washable flux:
1) You *MUST* wash it off -- it's a lot more corrosive than the Rosin or No-Clean types
2) You need hot water to fully get it off. I use a cheapo Harbor Freight ultrasonic cleaner with built-in heat and it works really well for the purpose.
Personally, I prefer it because the higher activity makes better joints.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
