Topic: square wave signal flow rate sensor (Read 4926 times) previous topic - next topic
bikehikeclimb
I just got a flow rate sensor and it says to get the reading: "The output signal is a square wave signal, whose frequency varies linearly with flow rate".
What does this mean?
Here is the product sheet: http://www.gemssensors.com/uploadedFiles/Literature/Product_PDFs/FT-330.pdf
Thanks for the help,
Kyle
retrolefty
It means to read the flow rate you will have to interface the signal to a digital input pin and measure the frequency of the signal to then determine the flow rate. The datasheet shows the relationship for two different size flow meters:
P/N        Thread       Flow Range   Pulses/GAL.    Frequency (Hz)
226000    3/8 NPT     0.2-2 GPM    10200            34-343
226100    3/8 NPT     0.4-4 GPM     -------           28-340
So if you measure the frequency of the signal you can then correlated it to a specific flow rate at that time.
You will also have to decide if you just want to just know flow rate at any given time, or if you also want to keep track of total gallons flowed over a given period, that is a so called flow totalizer.
Lefty
bikehikeclimb
How do you measure the frequency of the signal  with the arduino? Is that PWM?
retrolefty
No not PWM. There have been posting on how to write a frequency measurement sketch and even some software libraries posted to help make it easier to intergrate into your sketch. I haven't yet needed to write such a function so can't really recommend a 'best method".
Perhaps if you could explain what all your Arduino needs to accomplish, it would help with ideas and suggestions?
Lefty
bikehikeclimb
All I am trying to do is to keep track of the gallons that flow over a given time and read out the current gallons per minute used and the total gallons used to a LCD screen.
bikehikeclimb
All I really need to know is how to measure frequency, everything else I know how to do.
weirdo557
using micros is kinda redundant. theres already a function called pulseIn that measures the time between pulses, high or low.
bikehikeclimb
With using pulseIn is the recording interval fast enough so that I the accuracy of gallons per minute is not messed up over time?
weirdo557
ok, so it looks like you need two things. count the number of pulses and find the flow rate. what you would need is an interrupt. an interrupt will run a small piece of code when your sensor outputs a high, a low, or a high to low, or low to high  reading. this is done automatically.
the small piece of code should only update a counter and should be as small as possible.
when you want to see how much has flowed, you would divide the number of pulses by the amount of pulses per gallon
"10200" is what the previous posts say.
to find the instantaneous flow, find the period of the pulses. you should do this in the main loop as it is not as time sensitive. find the period, then find the number of pulses per whatever unit of time that would be (hertz). once you have that you can use it with the number of pulses per gallon to find the flow rate.
Simpson_Jr
Indeed, i hadn't used it before, it saves writing some lines, thank you !
One thing, Pulsein() seems to measure the time a pin is High or Low, not... High and Low.
From the reference :
Reads a pulse (either HIGH or LOW) on a pin. For example, if value is HIGH, pulseIn() waits for the pin to go HIGH, starts timing, then waits for the pin to go LOW and stops timing.
To measure frequency you'll need both, so maybe you need to multiply the pulsein() value by two.
I guess both methods are more then fast enough to measure.
Minimum value to measure with pulsein() is 10 microseconds.
In theory you could measure up to 50.000Hz, about 150 times as fast as the max output of the sensors.
BTW, Any idea how the sensors behave below 0.2 or 0.4 GPM ?  it's 288/576 Gallons a day...
SouthernAtHeart
Don't know if this will help, but this sensor is basically the same I think.  I'm currently using one of these:
http://www.seeedstudio.com/forum/viewtopic.php?f=4&t=989&p=3632#p3632
bikehikeclimb
This is how I have written the sketch so far...
int pin = 7;
unsigned int duration;
int pulsesEqualToGallon = 4994; //Found this in an archive datasheet
int pulses = 0;
float totalGallons = 0;
float oldTotalGallons;
  pinMode(pin, INPUT);
  Serial.println("Total gallons \n 0");
  duration = pulseIn(pin, HIGH);
  //Count if duration is greater than 0
  if (duration > 0){
    pulses++;
    oldTotalGallons = totalGallons;
    //Check if pulses are greater than pulses equal to gallon
    if (pulses > pulsesEqualToGallon ){
      totalGallons++;
      pulses = 0;
    if (totalGallons > oldTotalGallons){
      Serial.println(totalGallons);
supercap
can pulseIn be used to measure frequency to determine output pin? i need a sketch that sets one pin high at a specific frequency and another pin high at another frequency. can anybody help?
weirdo557
yeah, pulse in give you your period, use that to calculate your frequency. store that calculation in a variable, then use "if" statements to compare that number to whatever number you want. if its true, make your pin high, if its not, make it low.
robtillaart
You could also use an interrupt based counting mechanism as I did on - http://www.arduino.cc/playground/Main/EEM12L-32AKWhMonitoring - Although my sketch was for a KWH meter the principle is identical. The advantage is that the pulses are counted "in the background" and that you can fetch the counter any time you need it.
In the sketch the number 2000 is the factor between pulses and KWH, you should replace that by 4994 (number you found)
succes
Rob Tillaart
