Topic: Agentuino - A lightweight SNMP Agent (Read 55140 times) previous topic - next topic
Spandy19
Hey Chris
Thanks heaps for the detailed explanation :)
I am configuring my device now..I think I should be able to get my results graphed.I will post it, when I get it working..
Cheers
Spandy19
Hey Chris
I followed your instructions, still I am getting the below error..
any tips on how to solve the error..:( plz advice..
Code: [Select]
RRDTool Command:
/usr/bin/rrdtool graph - \
--imgformat=PNG \
--start=-86400 \
--end=-300 \
--title='MCR Sensor - Temperature' \
--base=1000 \
--height=120 \
--width=500 \
--alt-autoscale-max \
--lower-limit=0 \
--vertical-label='' \
--slope-mode \
--font TITLE:12: \
--font AXIS:8: \
--font LEGEND:10: \
--font UNIT:8: \
DEF:a="/var/lib/cacti/rra/28/1020.rrd":snmp_oid:AVERAGE \
GPRINT:a:LAST:"Current\:%8.2lf %s"  \
GPRINT:a:MAX:"Maximum\:%8.2lf %s\n"  \
GPRINT:a:AVERAGE:"Average\:%8.2lf %s"  \
GPRINT:a:MIN:"Minimum%8.2lf %s"
RRDTool Says:
ERROR: opening '/var/lib/cacti/rra/28/1020.rrd': No such file or directory
and also "Graph Item" (average) under "Graph Template" its "GPRINT type " is it load average or and be normal ??
Did you create your own Gprint type ??
hope I dint confuse you with all the "G"z ..thank you for ur help :)
Spandy19
itz working ..it is working :D
thankz heaps chris
Spandy19
Well It wont draw the points on graph.. It is receiving the info as seen below in the image..
Can't figure out why :s plz help!!
yesyes
Well, that's progress...
Not sure why the graphs don't show...
Can you please post a few screenshots of your cacti config? Specifically  a screenshot of the page shown on the 5th picture in my post (the one with all the screenshots). Then, on that same page click on the first item in the list on the top (should be the graph item) and post another screenshot of that page.
Chris
My Astro and DIY projects website: http://yesyes.info/
Spandy19
I not really sure how to post screen shots..I am posting images..
Graph template screen shots (image graph1 and graph2)
Item #1 current reading (image graph3)
Humidity graph setting (image graph 5, graph6)
Temperature graph setting (image graph7,graph8)
Spandy19
and the rest of the images
Spandy19
I really appreciate your help Chris :)
Spandy19
latest update..Y axis limits are realistic now! (0 to 100)
yesyes
I think the problem is shown on the first screenshot. You only have GPRINT items in your graph template. These are text prints. You need to add an AREA item (filled graph). See the 2nd and 3rd (from bottom) of my screenshots...
Chris
Spandy19
Sweet!!!! thnk u :) (dnt know how I missed that)
Have good day!!
Cheers
yesyes
I take it that means it's working? ;-) Or have you not tried yet?
Chris
Spandy19
Update.. There is grab in data cause I disconnected the sensor.
I was looking at your watchdog circuit very useful.. :)I am facing the same prob..SNMP gets stuck with unknow packet. That's my next step...
Spandy19
oh yes itz working ..Yaaayeee and big HI5 to u :)
yesyes
Great. It's working .. ;-)
I just realised that we were discussing this in the Agentuino thread. I hope LAVco doesn't mind... ;-)
Chris
