Topic: NMEA 2000 Shield (Read 182536 times) previous topic - next topic
hobi
@allen652: I also look to broadcast information to a Triton T41 MFD.
I have been crawling on the web to find out some raw binary file, that I could use to check my code but no luck.
Therefore, what I have is the NMEA decoder ( Good that this was made open, really a huge piece of work)  that will help me to understand what the Triton sends out initially when powered up, but I will have to reverse the decoder, and assemble some PGNs ( like boat COG , wind direction) and send that to the Triton.
It would be of great help if you could accept to share the piece of SW you did to boradcast PGNs... Please.
What I am concerned about is the address claim, and also device capabilities / ISO aCK stuff.
Thanks in advance.
jpjcb66
#31
Oct 09, 2014, 12:36 pm Last Edit: Oct 09, 2014, 04:41 pm by jpjcb66 Reason: 1
Hello everyone,
I have trouble with PGN 127489 + MFDe7 Raymarine and I have not response from "allen652" .
Can not display engine temperature water.
Can someone please help me?
thank you
jp
allen652
#32
Oct 09, 2014, 04:32 pm Last Edit: Oct 23, 2014, 10:04 am by allen652
I am using an arduino MEGA and the MCP2515 library as mentioned and worked on by coryjfowler https://github.com/coryjfowler/MCP2515_lib.
I built my own shield for a few dollars by purchasing the components from digikey.com. The design is based on seeedstudio's canbus http://www.seeedstudio.com/wiki/images/7/78/CAN-BUS_Shield_v0.9b.pdf.
IC CAN Transceiver: MCP2551-I/P-ND
IC CAN Controller: MCP2515-I/P-ND
16 MHZ Crystal: XC1748-ND
Resistors: 10kohm & 4.7kohm
Capacitors: (2) 22pf & (2) 100nf
I am using non-certified NMEA2000 cabling products that I had manufactured for my current project. I have several available for sale below if interested. See images.
2 meter cable (Male to Female) - $7.5 each
T adapter - $7 each
Male rear panel mount connector - $5 each
I'll put some sample code in my next post.
allen652
Code: [Select]
#include <mcp_can.h>
#include <SPI.h>
MCP_CAN CAN0(53);                                      // Set CS to pin 53
//MCP_CAN CAN0(2); //for my new prototype shield
unsigned char stmp[8] = {0, 0xA0, 0x41, 0, 0, 0, 0, 0};
unsigned char extpgn[26] = {0, 0xA0, 0x41, 0, 0, 0, 0, 0};
void setup(){
  // init can bus, baudrate: 250k
  if(CAN0.begin(CAN_250KBPS) == CAN_OK) Serial.print("can init ok!!\r\n");
  else Serial.print("Can init fail!!\r\n");
  //testPGN127489();
  //transmitPGN127489(0,55.5,164,171,13.54,15.8,221,11.2,32.1,38,44,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0);
  testRPM();
void loop(){
  //PGN 127488 binary 011111001000000000
  //for id try 110 + above + 00000000 = 11001111100100000000000000000 = hex 19F20000
  //highest priority = 000 try 00001111100100000000000000000 = hex 1F20000 = dec 32636928
  //PGN 127489 binary 011111001000000001
  //for id try 00001111100100000000100000000 = hex 1F20100 = dec 32637184
  // send data:  id = 0x00, extended frame, data len = 8, stmp: data buf
  CAN0.sendMsgBuf(32636928L, 1, 8, stmp);
  //testPGN127489();
  //transmitPGN127489(0,55.5,164,171,13.54,15.8,221,11.2,32.1,38,44,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0);  //with checkEngine flag set to true
  transmitPGN127489(0,55.5,164,171,13.54,15.8,221,11.2,32.1,38,44,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0);  //with checkEngine flag set to false
void testPGN127489(){
  //if an engine parameter is not available, set it to 255
  unsigned char extpgn[26] = {0, 208, 14, 170, 13, 151, 136, 236, 4, 37, 2, 112, 207, 11, 0, 255, 255, 255, 255, 1, 0, 0, 0, 0, 255, 255};  //decimal values
  unsigned char temp[8] = {0,0,0,0,0,0,0,0};
  int cur=0;
  for(int i = 0; i<=3; i++){
      temp[0] = i; //frame counter
      if (i==0){
          temp[1] = 26; //total bytes in fast packet
          //send the first 6 bytes
          for(int j = 2; j<8; j++){
               temp[j]=extpgn[cur];
               cur++;
      } else{
           for(int j = 1; j<8; j++){
               temp[j]=255;
           //send the next 7 data bytes
               cur++;
      CAN0.sendMsgBuf(32637184L, 1, 8, temp);
      delay(1);
void testRPM(){
  int rpm;
  for(int i = 0; i<=4200; i=i+100){
      rpm=(i*4);
      stmp[2]=rpm/256;
      stmp[1]=rpm-(stmp[2]*256);
      delay(100);
void transmitPGN127489(int engineInstance, float engineOilPress, float engineOilTemp, float engineCoolantTemp, float battery,
  float fuelRate, float engineHours, float engineCoolantPress, float engineFuelPress, float engineLoad, float engineTorque, bool flagCheckEngine,
  bool flagOverTemp, bool flagLowOilPress, bool flagLowOilLevel, bool flagLowFuelPress, bool flagLowSystemVoltage, bool flagLowCoolantLevel,
  bool flagWaterFlow, bool flagWaterInFuel, bool flagChargeIndicator, bool flagPreheatIndicator, bool flagHighBoostPress, bool flagRevLimitExceeded,
  bool flagEgrSystem, bool flagTPS, bool flagEmergencyStopMode, bool flagWarning1, bool flagWarning2, bool flagPowerReduction,
  bool flagMaintenanceNeeded, bool flagEngineCommError, bool flagSubThrottle, bool flagNeutralStartProtect, bool flagEngineShuttingDown){
  unsigned int extpgn[26]; // {0, 208, 14, 170, 13, 151, 136, 236, 4, 37, 2, 112, 207, 11, 0, 255, 255, 255, 255, 1, 0, 0, 0, 0, 255, 255};  //decimal values
  unsigned char temp[8]; // {0,0,0,0,0,0,0,0};
  float v;
  extpgn[0]=engineInstance;
  v=engineOilPress;
  v=v*68.94757;
  //extpgn[2]=v/256;
  //extpgn[1]=v-(extpgn[2]*256);
  extpgn[2]=highByte((int) v);
  extpgn[1]=lowByte((int) v);  //this works well. I should change the code below to use this format.
  v=engineOilTemp;
  v=(((v-32)*5/9)+273)*100;
  extpgn[4]=v/256;
  extpgn[3]=v-(extpgn[4]*256);
  v=engineCoolantTemp;
  extpgn[6]=v/256;
  extpgn[5]=v-(extpgn[6]*256);
  v=battery;
  v=v*100;
  extpgn[8]=v/256;
  extpgn[7]=v-(extpgn[8]*256);
  v=fuelRate;
  v=v*37.8541;
  extpgn[10]=v/256;
  extpgn[9]=v-(extpgn[10]*256);
  v=engineHours;
  v=v*3600;
  //extpgn[14]=v/16777216;
  //extpgn[13]=(v-(extpgn[14]*16777216))/65536;
  //extpgn[12]=(v-((extpgn[14]*16777216)+(extpgn[13]*65536)))/256;
  //extpgn[11]=v-((extpgn[14]*16777216)+(extpgn[13]*65536)+(extpgn[12]*256));
  int tempVar = (long) v >> 16;
  extpgn[14]=highByte(tempVar);
  extpgn[13]=lowByte(tempVar);
  tempVar = (long) v & 0xFFFF;
  extpgn[12]=highByte(tempVar);
  extpgn[11]=lowByte(tempVar);
  v=engineCoolantPress;
  v=v*68.94757;
  extpgn[16]=v/256;
  extpgn[15]=v-(extpgn[16]*256);
  v=engineFuelPress;
  v=v*689.4757;
  extpgn[18]=v/256;
  extpgn[17]=v-(extpgn[18]*256);
  extpgn[19] = 255; //nmea2000 reserved byte
  int engineStatus1P1 = B00000000;
  int engineStatus1P2 = B00000000;
  int engineStatus2 = B00000000;
  if (flagCheckEngine) engineStatus1P1 |= B00000001;
  if (flagOverTemp) engineStatus1P1 |= B00000010;
  if (flagLowOilPress) engineStatus1P1 |= B00000100;
  if (flagLowOilLevel) engineStatus1P1 |= B00001000;
  if (flagLowFuelPress) engineStatus1P1 |= B00010000;
  if (flagLowSystemVoltage) engineStatus1P1 |= B00100000;
  if (flagLowCoolantLevel) engineStatus1P1 |= B01000000;
  if (flagWaterFlow) engineStatus1P1 |= B10000000;
  if (flagWaterInFuel) engineStatus1P2 |= B00000001;
  if (flagChargeIndicator) engineStatus1P2 |= B00000010;
  if (flagPreheatIndicator) engineStatus1P2 |= B00000100;
  if (flagHighBoostPress) engineStatus1P2 |= B00001000;
  if (flagRevLimitExceeded) engineStatus1P2 |= B00010000;
  if (flagEgrSystem) engineStatus1P2 |= B00100000;
  if (flagTPS) engineStatus1P2 |= B01000000;
  if (flagEmergencyStopMode) engineStatus1P2 |= B10000000;
  if (flagWarning1) engineStatus2 |= B00000001;
  if (flagWarning2) engineStatus2 |= B00000010;
  if (flagPowerReduction) engineStatus2 |= B00000100;
  if (flagMaintenanceNeeded) engineStatus2 |= B00001000;
  if (flagEngineCommError) engineStatus2 |= B00010000;
  if (flagSubThrottle) engineStatus2 |= B00100000;
  if (flagNeutralStartProtect) engineStatus2 |= B01000000;
  if (flagEngineShuttingDown) engineStatus2 |= B10000000;
  extpgn[20]=engineStatus1P1;
  extpgn[21]=engineStatus1P2;
  extpgn[22]=engineStatus2;
  extpgn[23]=0;
  extpgn[24]=engineLoad;
  extpgn[25]=engineTorque;
  int cur=0;
      if (i==0){
               cur++;
      } else{
               temp[j]=255;
               cur++;
      delay(1);
  //for debugging
  Serial.print("Data = ");
  for(int j = 0; j<26; j++){
    if (j<25){
      Serial.print(extpgn[j]);
      Serial.print(", ");
      Serial.println(extpgn[j]);
  Serial.print("HexData = ");
    if (j<25){
      Serial.print(extpgn[j],HEX);
      Serial.print(", ");
      Serial.println(extpgn[j],HEX);
jpjcb66
#34
Oct 09, 2014, 04:55 pm Last Edit: Oct 09, 2014, 04:58 pm by jpjcb66 Reason: 1
Thank you for your reply.
Here is my current code for this part :
Code: [Select]
// ++++++++++++++++++++++++++++++++++++ Engine Parameters, Dynamic ++++++++++++++++++++++++++++++++++++
  updateRate = 500; // 2 * / s
  priorite = 5;
  PGN = 127489;  // Paramètres environnementaux bus NMEA 2000 (N2K)
  source = 35;   // Airmar = 35
  adresse = priorite * 67108864 + PGN * 256 + source;
  float tempwc =  95; //TWEng;  // Celsius  Engine Water Temp
  long tempwk =  100 * ( tempwc + 273.15 );
  long tempw1 = ( tempwk & 0b1111111100000000 ) >> 8;  // mise en forme format CAN 16bits
  long tempw2 =   tempwk & 0b0000000011111111;
  float PressEng = 200;  // Lecture capteur pression resolution = 8 bits pour essai.
  long PressEng_ = 20 * PressEng;
  long PressEng1 = ( PressEng_ & 0b1111111100000000 ) >> 8;  // mise en forme format CAN 16bits
  long PressEng2 =   PressEng_ & 0b0000000011111111;
  message.id = adresse;
  message.ide = 1;
  message.rtr = 0;
  message.dlc = 8;
  message.data[0] = 0;   //  SID
  message.data[1] = 0;   //  Engine instance  8bits    0=Single Engine
  message.data[2] = 0;   //  doit etre  à 0 pour lecture 2 octets plus bas. Oil press = 0 si 255
  message.data[3] = PressEng2; //PressEng2;
  message.data[4] = PressEng1; //PressEng1;   //  Oil   Press huile 1=0,3  2=0,5  3=0,8  4=1b  28=7,2b
  message.data[5] = 255;   //  ????
  message.data[6] = tempw2;   //  Temperature eau moteur - 16 bits (sonde DS18B20)
  message.data[7] = tempw1;   //  Temperature eau
/* Serial.print("TEMPERATURE EAU MOTEUR : ");
Serial.print(tempw2);  Serial.print(" - ");
Serial.println(tempw1);
  SendPaquet();
  message.data[1] = 1;  // 1 paquet supplémentaire
  message.data[2] = 0;  // Alternateur
  message.data[3] = 0;  // Alt
  message.data[4] = 0;  // Fuel rate
  message.data[5] = 0;  // Fuel rate
  message.data[6] = 1;  // Hour
  message.data[7] = 0;  // Hour
  message.data[8] = 0;  // Hour
  SendPaquet();
  message.data[1] = 2;  // 1 paquet supplémentaire
  message.data[2] = 4;  // Hour
  message.data[3] = 0;  // Coolant press
  message.data[4] = 0;  // Coolant press
  message.data[5] = 0;  // Fuel press
  message.data[6] = 0;  // Fuel press
  message.data[7] = 0;  // reserved
  message.data[8] = 0;  // Discrete Status 1
  SendPaquet();
  message.data[1] = 3;  // 1 paquet supplémentaire
  message.data[2] = 0;  // Discrete Status 1
  message.data[3] = 0;  // Discrete Status 2
  message.data[4] = 0;  // Discrete Status 2
  message.data[5] = 0;  // Percent Engine Load
  message.data[6] = 0;  // Percent Engine Torque
  SendPaquet();
  delay(updateRate);
spicetraders
T adapter - $7 each
I have found that NEMA2000 is hardware wise follows the older DEVICENET so many parts interchange with out issues.
jpjcb66
#36
Oct 09, 2014, 05:14 pm Last Edit: Oct 09, 2014, 06:59 pm by jpjcb66 Reason: 1
Compliments, Beautiful Code.
But I have to try to translate Arduino uno.
I did not see how you code:
address = priority * 67108864 * 256 + PGN + source;
allen652
I should probably comment my code better (and more often).
jpjcb66: The first 3 bits of the id is the priority, the next 18 bits are the PGN, and the last 8 bits are the source address.
See the comments in my code above in void loop().
priority = 000
PGN = 011111001000000000
source = 00000000
00001111100100000000000000000 binary = 32636928 decimal
Code: [Select]
// send data:  id , extended frame, data length = 8, data buffer
jpjcb66
#38
Oct 09, 2014, 06:45 pm Last Edit: Oct 10, 2014, 02:23 pm by jpjcb66 Reason: 1
@allen652
I understand !
You put "source" = 0x0
Code Airmar = 0x25 (35dec).
There exists an array of manufacturer codes ?
For example what is the Volvo Penta code ?
Your code is perfect, thank you infinitely.
jp
farabin
Hi friends
I want to read 2 periodic data from maretron WSO100 module. PGN #130306 for wind data & #130310 for environmental parameters. As I read this PGNs send periodically every 100 ms &  500 ms...
I use LPC1768 controller and do this steps to read wind data:
1) set CAN Controller baud rate to 250 kbit/sec
2) set ID to 130306(0x01FD02) in extended format
3) read can receive buff...
But I don't receive any data on bus!!!
what should I do??? what's wrong???
please help me...
Thanks a lot
Prof67
Want to read NEMA2000 stream from a Garmin Depth founder with a Arduino Due.
Just this device on NEMA network.
Did someone have code reference ?
  :D
elgui
#41
Mar 30, 2015, 08:57 pm Last Edit: Mar 30, 2015, 08:59 pm by elgui
I'm about to buy a "triducer", the Airmar DST800. It's going to send depth/temp/speed via NMEA2000.
As a java programmer with zero experience with Arduinos (but lot of time to spend on it), do you think I have a chance, using existing resources, to decode these informations and display it on a e-ink display shield ?
I don't absolutely need a ready-to-use solution, and a simple "yes you can" would be much appreciated to preserve my motivation ^^
Of course, I'll be back later with more accurate questions ;)
CrossRoads
Yes you can.
Only challenge is parsing the NMEA data stream to pick out the pertinent info.
And then sorting out the e-ink interface. Probably just another serial data stream?
elgui
Thank you CrossRoads,
I have an idea about the parsing challenge, and I guess I can use some existing code that parse GPS datas and adapt it. The e-ink display does not scares me that much, because if I don't succeed, I still have other display options.
I'll put my code somewhere on this forum if I reach my goal =)
See you !
timolappalainen
Hi All,
I have been trying to find NMEA2000 shield without success, so I wrote my own. It can act as listener only and forward data to PC in Actisense or clear text format. Or it can act as Termperature sensor node with automatic address claiming. Or as I am making it as a NMEA0183 combiner/ NMEA200 converter and sensor node.
Library works with Mega board with MCP2551 chip or with Due board with its internal CAN controller.
Anybody interested?
