Topic: Arduino Serial I/O expansion, Serial Peripheral Interface (SPI) using MPC23S08 (Read 1 time) previous topic - next topic
hesspet
Hello!
I was searching for hours for a working sample of the SPI version of the MPC23x08. I run into troubles with the configuration of the SPI Interface (Phase and Clock). For all here's a small running sample:
#define CONTROL_BYPE 0x40 // 0100 0000
//                                |||+-- R/W 0 == write
//                                ||+--- A0
//                                |+---- A1
#define chipSelectPin 10
#define BITORDER MSBFIRST
#define DATAMODE SPI_MODE3   // testes with  Mode  2 and 3
  // setup the protocol
  SPI.setClockDivider(SPI_CLOCK_DIV2);   // testes also with higher values mit 2
  SPI.setBitOrder(BITORDER) ;
  SPI.setDataMode(DATAMODE) ;
  // prepare for output
  SPI.begin();
  pinMode(chipSelectPin, OUTPUT);
  digitalWrite(chipSelectPin, HIGH);
  digitalWrite(chipSelectPin, LOW);
  SPI.transfer(0x40);
  SPI.transfer(0x00);                   // select the IODIR register
  SPI.transfer(0xff);                   // set register value-all high, sets all pins as outputs on MCP23008
  SPI.end();
// flash all connected LED
  SPI.begin();
  SPI.transfer(0x40);
  SPI.transfer(0x09);                   // select the GPIO register
  SPI.end();                             // stop talking to the device
  delay(500);                           // wait for 1/2 a second
  SPI.begin();
  SPI.transfer(0x40);
  SPI.transfer(0x00);                   // set register value-all low
Hope this will speed up the work for others.
And don't forget Arduino MSIO goes to Chip MSIN and Arduino MSIN to MSIO   :~ This was my bigges problem!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
