Topic: Welcome to this forum board! (Read 9645 times) previous topic - next topic
joebutler10
Nov 02, 2017, 11:17 pm Last Edit: Nov 07, 2017, 12:04 am by joebutler10
The support for Intel®-based platforms in Arduino Create just launched today!
A general getting started guide can be found here
If you're using the UP Squared Grove IoT Developer Kit, there is a separate guide here
Supported platforms:
  • Intel® Atom, Intel® Core™, or Intel® Xeon® Processors
Supported Operating Systems:
  • Ubuntu 16.04 LTS
  • Wind River Pulsar
For more info on using compatible libraries, see https://software.intel.com/en-us/articles/using-intel-libraries-in-arduino-create
For info specifically about MRAA and UPM I/O and sensor libraries see https://software.intel.com/en-us/articles/mraa-and-upm-basics-in-arduino-create
Other useful support links for various libraries:
OpenCV - https://github.com/opencv/opencv
MRAA - https://github.com/intel-iot-devkit/mraa
UPM - https://github.com/intel-iot-devkit/upm
Intel® Math Kernel Library - https://software.intel.com/en-us/forums/intel-math-kernel-library
AWS - https://github.com/intel-iot-devkit/aws-iot-device-sdk-cpp-arduino-create
Microsoft Azure - https://github.com/intel-iot-devkit/azure-iot-sdk-c-arduino-create
ballscrewbob
Does that mean I could use it on my Xeon based server ?
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
joebutler10
#2
Nov 03, 2017, 10:56 pm Last Edit: Nov 03, 2017, 11:07 pm by joebutler10
yes, given you are running Ubuntu 16.04 it should work, keep in mind there are two flows for getting it connected, one where you enter an IP address (need to be on the same subnet for it and have SSH server on your target), and the other where you enter in some commands on your target for it to connect (being on the same network isn't required).
You can also run Arduino Create on the same computer that you upload sketches to, using 127.0.0.1 as the IP address for example.
ballscrewbob
So its a Linux ONLY based project ?
Would hate to have to change my OS (server2012)
joebutler10
Yes, you can only connect to and run sketches on Linux based systems.  However, I can't think of a reason why a virtual machine running on your Windows server wouldn't work.
ballscrewbob
Trying to get my head around this as it says Intel based systems but seems to be for only one quite expensive board using only Linux.
Are there plans to include the other Intel based boards such as the 101 Curie etc. etc. ?
Also are there plans to include windows OS ?
joebutler10
To be more clear, it's Intel-based systems that are 64-bit capable running Linux.  If you're referring to the UP Squared board, the only difference there is that the OS comes pre-configured and setup is a little easier than a laptop or NUC.
No need to have that specific hardware to get started, I'm connecting to my development laptop that's running Ubuntu and I'm able to upload sketches just fine.
the Arduino 101 is already supported in Arduino Create (see attached).
I can't comment on Windows support, currently using a VM in Windows is the only way.
If you're interested in more info, I'll be giving a presentation at an online conference tomorrow 2:20pm PST.
http://globaliotfest.withthebest.com/
schedule:
https://drive.google.com/file/d/0B49nw1tgv7FCNlZPbUQzTXJnSjQ/view
ballscrewbob
My apologies Joe.
I thought this was some new platform asides from CREATE.
I would have liked to sit in on the presentation but I have a hell of a schedule tomorrow.
Part of which involves an 80k ea way trip to get some pipe to put in a trench so I can get water to my workshop before the snow comes here in Northern Canada.
Will keep my eye out for the boards when the price drops to a better break point.
Its a good release date just before winter as from here on until around March April the forums seems to get a lot more action. (cabin fever maybe LOL).
I wish you luck.
joebutler10
Thanks, and no worries, I'll see what I can do to make our wording more clear where possible.  The presentation will be recorded, I'll post the link to the recording in a few days.
Good luck with the pipe... I'm hoping to lay some myself this winter, I'm here in Arizona so it's just starting to get tolerable outside :)
