Topic: Problems with arduino bootloader (new forum) (Read 3147 times) previous topic - next topic
kitsaros
You may have seen my topic on the old forum : http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1294997078
To reassume i have two "Atmega168 20pu" chips without any bootloader
I have tried three methods to put the bootloader
a) using arduinoisp with 16 mhz crystal
b) bitbang mode
c) using usbtinyISP
on all of these methods i get :
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
using avrdude from the command line
"C:\Program Files\Arduino\arduino-0022\hardware\tools\avr\bin\avrdude.exe" -C "C:\Program Files\Arduino\arduino-0022\hardware\tools\avr\etc\avrdude.conf" -p m168 -P com5 -c avrisp -b 19200 -F
I get :
avrdude: Device signature = 0x000000
avrdude: Expected signature for ATMEGA168 is 1E 94 06
same are the results using winavr...
Coding Badly
Run this...
Code: [Select]
C:\Program Files\Arduino\arduino-0022\hardware\tools\avr\bin\avrdude.exe" -C "C:\Program Files\Arduino\arduino-0022\hardware\tools\avr\etc\avrdude.conf" -p m168 -P com5 -c avrisp -b 19200 -v -v -v
Post the results.  Please use code tags.
kitsaros
#2
Feb 03, 2011, 09:23 pm Last Edit: Feb 03, 2011, 09:26 pm by kitsaros Reason: 1
There you go . I am using usbtiny.
Code: [Select]
2\hardware\tools\avr\etc\avrdude.conf" -p m168 -c usbtiny -b 19200 -v -v -v
avrdude.exe: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
            System wide configuration file is "C:\Program Files\Arduino\arduino
            Using Port            : lpt1
            Using Programmer      : usbtiny
            Overriding Baud Rate  : 19200
            AVR Part              : ATMEGA168
            Chip Erase delay      : 9000 us
            PAGEL                 : PD7
            BS2                   : PC2
            RESET disposition     : dedicated
            RETRY pulse           : SCK
            serial program mode   : yes
            parallel program mode : yes
            Timeout               : 200
            StabDelay             : 100
            CmdexeDelay           : 25
            SyncLoops             : 32
            ByteDelay             : 0
            PollIndex             : 3
            PollValue             : 0x53
            Memory Detail         :
                                     Block Poll               Page
         Polled
              Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW
MaxW   ReadBack
              eeprom        65     5     4    0 no        512    4      0  3600
 3600 0xff 0xff
                                     Block Poll               Page
         Polled
MaxW   ReadBack
              flash         65     6   128    0 yes     16384  128    128  4500
 4500 0xff 0xff
                                     Block Poll               Page
         Polled
MaxW   ReadBack
              lfuse          0     0     0    0 no          1    0      0  4500
 4500 0x00 0x00
                                     Block Poll               Page
         Polled
MaxW   ReadBack
              hfuse          0     0     0    0 no          1    0      0  4500
 4500 0x00 0x00
                                     Block Poll               Page
         Polled
MaxW   ReadBack
              efuse          0     0     0    0 no          1    0      0  4500
 4500 0x00 0x00
                                     Block Poll               Page
         Polled
MaxW   ReadBack
              lock           0     0     0    0 no          1    0      0  4500
 4500 0x00 0x00
                                     Block Poll               Page
         Polled
MaxW   ReadBack
              calibration    0     0     0    0 no          1    0      0     0
    0 0x00 0x00
                                     Block Poll               Page
         Polled
MaxW   ReadBack
              signature      0     0     0    0 no          3    0      0     0
    0 0x00 0x00
            Programmer Type : USBTINY
            Description     : USBtiny simple USB programmer
avrdude.exe: Using SCK period of 10 usec
CMD: [ac 53 00 00] [00 00 00 00]
avrdude.exe: initialization failed, rc=-1
            this check.
avrdude.exe done.  Thank you.
Using usbtinyISP i can read with success my original atmega 368 bundled with my arduino duemillanove.
Thanks
Coding Badly
Do you have a 16 MHz crystal connected to the 168 processor?
kitsaros
Coding Badly
It looks like the 168 processor is not responding to the programmer.  I know that doesn't help but, unfortunately, it's all I have to offer.  You've proven the programmer and software are working.  I cannot think of anything else to try.
kitsaros
Hello again and thanks to all for your support and feedback !
I have sent back the two ATMEGA 168 and i got back two others from the same seller.
Now everything works like a charm.
The first one i have put the bootloader using usbtiny + arduino (without the usb cable) with the ICSP cable. No problems at all i just used the arduino gui normally.
The second one i have used the usbtiny with my handmade arduino breadboard. I only pressed the reset button once then the bootloader was successfully loaded via the arduino gui.
So it was so simple that i did not even use avrdude directly but only within arduino GUI
Thanks !
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
