Topic: printing multiple variables in columns in serial monitor (Read 6888 times) previous topic - next topic
cmazzoli
so i have my ardunio attached to my RPi and have a sketch running with a temp sensor that gives voltage, sensor value and degree c. what i want is to have those numbers in different columns.
i would like to remove Serial.print("Sensor value: "); Serial.print(", Volts: "); Serial.print(", degrees C: ");
so just the numbers appear, but when i remove them i get a crazy number.
I am still NOOB so please be nice! thanks!
here is the code
const int sensorPin = A0;
const float baselineTemp = 18.36;
  Serial.println("Sensor Value, Volts, temperature");
  int sensorVal = analogRead(sensorPin);
  Serial.print(sensorVal);
  float voltage = (sensorVal/1024.0) * 5.0;
  Serial.print(voltage);
  float temperature = (voltage - .5) * 100;
  Serial.println(temperature);
  delay(10000);
Delta_G
By getting some crazy number do you mean that the numbers you print get printed without any spaces being printed in between so it looks like one long number?
Why don't you just print spaces in between them?  Or better yet, use tabs so they'll line up in the monitor.
Code: [Select]
Serial.print(temperature);
Serial.print("\t");
Serial.print(Humidity);
Serial.print("\t");
Serial.print(someOtherVariable)
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
cmazzoli
ok i will do that next. i just want it to be as easy as possible for data logging purposes and still new at this.
if anyone has an easy method to do datalogging from arduino to RPi i am all ears to that too!
thanks for the input!
chris
MarkT
Use CSV format?  Simple to generate, highly portable.
cmazzoli
yeah i think i got the csv figured out. found a good youtube video on how to set it up using grabserial command in python.
what program would be best to use that data with?
MarkT
Its your data, you know what you want to do with it!
[although if you're using python clearly matplotlib and possibly pandas are libraries
that could be useful]
