Topic: MKRZero and Bluetooth connection help (Read 3140 times) previous topic - next topic
J_D
I am using an MKRZero to read sensor data on PC. This is done using an USB. I now need to communicate using Bluetooth. I am able to pair my bluetooth module (HC-06) to my PC but when I open a serial port no data is seen. The module LED stops flashing which I assume is an indication for the connection made but no data is seen. I really need to get this working. Any help is appreciated. Thanks!
ballscrewbob
Pairing doesn't have much to do with any data transfers themselves as its just a connection.
What sketch are you using ?
Please use code tags ( </> ) to post it unless its on CREATE then the shared link will do as well.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
sandeepmistry
J_D
J_D
#4
Nov 06, 2017, 06:28 pm Last Edit: Nov 06, 2017, 06:33 pm by J_D
Code: [Select]
  Serial1.begin(9600);
  while(!Serial1);
  checkBTForData();
  if(btrt)
      logOverBT();
void logOverBT(void)
  float accelX = imu.calcAccel(imu.ax);
  float accelY = imu.calcAccel(imu.ay);
  float accelZ = imu.calcAccel(imu.az);
  float gyroX = imu.calcGyro(imu.gx);
  float gyroY = imu.calcGyro(imu.gy);
  float gyroZ = imu.calcGyro(imu.gz);
  p1 = calcPressureData(analogRead(A1));
  p2 = calcPressureData(analogRead(A2));
  p3 = calcPressureData(analogRead(A3));
  p4 = calcPressureData(analogRead(A4));
  p5 = calcPressureData(analogRead(A5));
  p6 = calcPressureData(analogRead(A6));
  timeStamp = getTimeFromRTC();
  String dataString = timeStamp+String(accelX)+delim+String(accelY)+delim+String(accelZ)+delim+String(gyroX)+delim+String(gyroY)+delim+String(gyroZ)+delim+String(p1)+delim+String(p2)+delim+String(p3)+delim+String(p4)+delim+String(p5)+delim+String(p6);
  Serial1.println(dataString);
int calcPressureData(int analog){
  return 1023 - analog;
void checkBTForData(void)
  if(Serial1.available()){
      byteRead = Serial1.read();
       if(byteRead == BTRT_ENABLE)
        btrt = true;
         byteRead = 0;
        Serial1.write(BTRT_ENABLE_OK);
 else if(byteRead == BTRT_DISABLE)
        btrt = false;
         byteRead = 0;
        Serial1.write(BTRT_DISABLE_OK);
ballscrewbob
#5
Nov 06, 2017, 06:38 pm Last Edit: Nov 06, 2017, 06:43 pm by ballscrewbob
You may want to remove the while serial as it isnt really needed for most boards anymore.
There also appears to be some missing sketch at the beginning for defines etc.
EDIT
This link may well be of use to you as it covers the basics of the BT units and is the home page of one of the long standing members of this forum.
J_D
Ok, I will try once more. Thank You for the help!
J_D
I tried to program the module using AT commands but there is no OK response on the terminal. Also, another thing I noticed is that the bluetooth and Arduino on connecting using bluetooth turn off after a while. Any help?
ballscrewbob
Are you using a serial terminal on your computer to try AT commands ?
Don't try AT commands from your BT connected device until you know you can communicate via the computer that is connected to the board via USB first. (baby steps)
The IDE serial terminal is your first place to try but make sure the baud rates match your sketch.
J_D
It communicates when connected using an USB. But not with bluetooth
ballscrewbob
Exactly which BT module are you using (link preferable) ?
Then what terminal program are you using on the other BT enabled device ?
Just to see if I can replicate in some way.
J_D
I am using an HC-06 module (v1.06). On the PC I am using Putty to view the data or Arduino Serial Monitor. I even tried with TeraTerm.
ballscrewbob
That's great as I have some HC05 here (similar but a bit better than the 6)
If you could link or post the WHOLE sketch I might be able to replicate.
