Topic: Bit String to INT (Read 905 times) previous topic - next topic
waterboy550
Feb 03, 2011, 09:08 pm Last Edit: Feb 03, 2011, 09:35 pm by waterboy550 Reason: 1
I have the following code.
Serial.print(dht_dat[0], DEC);
This works get when printing dht_dat out via serial. The result is that the serial port prints out an interger. dht_dat is an array that stores 8bits in each value. I want to store this value as a int to use later in the program. I'm not having any success with this however. Any help would be great!
Here is the code to generate the dht_dat array. Sorry this isn't my code and I just started using it so I don't know that much about it.
//This is the call to make the array
for (i=0; i<5; i++)
   dht_dat = read_dht_dat();
//This is the read_dht_dat function that places the values into the array
byte read_dht_dat() {
   //Collect 8 bits from datastream, return them interpreted
   //as a byte. I.e. if 0000.0101 is sent, return decimal 5.
   //Code expects the system to have recently entered the
   //dataline low condition at the start of every data bit's
   //transmission BEFORE this function is called.
   byte i = 0;
   byte result=0;
   for (i=0; i< 8; i++) {
        //We enter this during the first start bit (low for 50uS) of the byte
        //Next: wait until pin goes high
        while(digitalRead(TEMP_RH_PIN)==LOW);
        delayMicroseconds(30);
        if (digitalRead(TEMP_RH_PIN)==HIGH)
        result |=(1<<(7-i));
        while (digitalRead(TEMP_RH_PIN)==HIGH);
   return result;
PaulS
Quote
Have you looked at the bitSet() and bitWrite() functions? Or the bitRead() counterpart?
