Loading...
Pages: [1] 2   Go Down
Author Topic: Arduino Sound triggered photography  (Read 3293 times)
Rotterdam, the Netherlands
Offline Offline
Newbie
Nomothumu
View Profile
Not the first, but always nice to show some results  smiley-lol Long exposures in dark room and triggered the flash on sound.
Used piezo for sound detection as in the trigger kit from the hiviz.com website. Hooked it up to my arduino to be abled to set the delay end reset time as I prefered. SCR to shortcut flash. Simple yet effective project.
Playing with different set-ups and delays (time between hard sound and flash trigger). Some results:
Logged
NO MORE THUMB MUSCLE!!!
Silly-con Valley, Ca, U.S.
Offline Offline
Sr. Member
Lernin' to tinker
View Profile
WWW
I love the board game and the glasses. What did you do to get the glasses moving like that?
Logged
10 PRINT CHR$(7)
20 GOTO 10
Offline Offline
Newbie
Nomothumu
View Profile
tape them on a shelve on wheels  smiley-razz
click to view notes, glasses taped to black shelve on wheels, on top of an inclined shelve (white)
Logged
0
Offline Offline
Sr. Member
bluesmokelabs.com
View Profile
WWW
What camera are you using there?
Logged
Offline Offline
Newbie
Nomothumu
View Profile
nikon d300s with sigma 70-200 f2.8 @ iso 200, F5.0 & 3s
Logged
Offline Offline
Newbie
Nomothumu
View Profile
Last result, getting to the point of perfection i'm looking for!
Breadboard diagram (left part is explaind on HIVIZ.com, arduino and part in red rectangle I've added myself):
and the code at the moment is:
Code:
const int ledPin = 13;
const int meetPin = 2;
const int flashPin = 7;
int meet = LOW;
pinMode(ledPin, OUTPUT);
digitalWrite(flashPin, LOW);
digitalWrite(meetPin, HIGH);
digitalWrite(ledPin, LOW);
meet = digitalRead(meetPin);
if (meet == LOW){
delay(100);                              // delay between sound and flash
digitalWrite(flashPin, HIGH);       // flash goes off
digitalWrite(ledPin, HIGH);         // LED during 'dead time'
delay(4000);                            //to make sure I only get one flash
« Last Edit: May 24, 2011, 06:49:57 am by timekeeper » Logged
Offline Offline
Newbie
View Profile
Wow that's cool!
Logged
+++ Check out The MajorDecibel Project Review, a third party project review site spotlighting electronics projects, parts, news, and resources. If you are interested in getting some exposure for your project please contact me +++
Offline Offline
Newbie
View Profile
tried completing this project myself, can not seem to get the flash to fire. followed the diagram you have shown here.. i think it may be the scr, mind sharing the part number you used? or possibly any other thoughts as to what might case it?
Logged
Offline Offline
Newbie
Nomothumu
View Profile
diagram was wrong. Black and white wires should be reversed. Updated the picture
Logged
Boston Suburbs
Offline Offline
God Member
I am above your silly so-called "Laws", Mister Ohm.
View Profile
WWW
>>> APPLAUDING <<<
I use an optocoupler with a lot of success, 2n35 I think.  I'd think a SSR (Solid State Relay) would be overkill, but would work.  Just remember older external flashes (and cheap new ones) sometimes dump a couple hundred volts or more across those terminals.  An NPN transistor isn't enough.
What type of flash, by the way, and what mode?  After a couple of paying gigs, I've finally actually purchased what might be considered my first "Professional" level hardware purchase, a Canon 430EX flash.  First TTL flash I've had and I must say it's night and day (literally in some respects) in terms of managing exposure.  I've not had time to "play" with it yet however, and I'm thinking that a TTL flash has to be ideal for stop motion- it quenches the strobe mid flash once appropriate lighting is sensed.  That means very short duration if set up right, I would think.. I've already found that my Interfit (el cheapo) 150w/s heads just can't be used for stop-motion, the flash duration is far too long.  They are great as a portable portrait setup, but those big tubes firing all that time.. motion blur when you are trying to avoid it.. painful.
Right now on my "to do" list is an idea you'll like:  I have collected and am triggering TEN salvaged flash units from disposable 35mm cameras.. with variable, programmable, and triggered delays, driven by Arduino.  Special Effects strobe that ought to be good for a ton of interesting effects....
« Last Edit: May 24, 2011, 08:30:14 am by focalist » Logged
When the testing is complete there will be... cake.
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
MOC3020, every time.
Fires my mix of old and new flashes flawlessly.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
HELP PLEASE!
I have follow this circuit but i have a problem.
I am using a wireless trigger PT-04TM to trigger the flash and when i connect to hiviz part all work ok, the flash´s trigger.
When i make the connections with the second SCR EC103D and Arduino, the trigger and flash don´t work, any suggestions???
I think the signal from piezo to arduino to the second SCR is no strong to trigger the the PT-04TM...
but i am a dumb in this questions
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
An SCR is polarised - have you got the flash lead the right way around?
Logged
Offline Offline
Newbie
View Profile
All connections are like the diagram
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Have you checked the polarity of the flash lead?
Logged
Pages: [1] 2   Go Up
Print
Jump to:
