Loading...
Pages: [1]   Go Down
Author Topic: Need for help : Weird Serial.print and Array read problems  (Read 288 times)
Indonesia
Offline Offline
Jr. Member
Arduino rocks
View Profile
Dear All.
I have very basic sketch below :
Code:
#include<string.h>
//-------------VARS to SEND------------------------------
int sendvarlen = 6;
char* sendvarname[6]={"s0","s1","s2","s3","s4","s5"};
char* sendvarval[6]={"0","0","0","0","0","0"};
long timetosend=millis();
  Serial.println("I'm Here !!!");
  if(millis() - timetosend > 1000)
    readsensor();
    Serial.println("=============================");
    devdata();
void readsensor()
  Serial.println("Analog Sensor Read results");
  char myread[10]="";
  for (int i = 0 ; i < sendvarlen ; i++)
    memset(myread, '\0', 10);
    sendvarval[i]="";
    itoa(analogRead(i),myread,10);
    delay(50);
    strcpy(sendvarval[i],myread);
    Serial.print(sendvarname[i]);
    Serial.print("=");
    Serial.println(sendvarval[i]);
void devdata()
  char mydata[500];
  strcpy(mydata, "My Sensordata is : ");
  for (int i=0; i<sendvarlen; i++)
    strcat(mydata,sendvarname[i]);
    strcat(mydata,"=");
    strcat(mydata,sendvarval[i]);
    if (i < sendvarlen-1)
      strcat(mydata,"&");
  Serial.print(mydata);
  Serial.println(" ");
And below is the results (dumped using) : tail -f /dev/ttyUSB1
Code:
s0=198
s1=244
s2=351
s3=440
s4=412
s5=273
73
My Sensordata is : s0=273&s1=273&s2=273&s3=273&s4=273&s5=273
73
s0=191
s1=262
s2=378
s3=449
s4=381
s5=234
34
My Sensordata is : s0=234&s1=234&s2=234&s3=234&s4=234&s5=234
34
Some weird thing from the results :
1. There is no "=============================" printed out.
2. all the "value" after "My Sensordata is" is just the last value got by readsensor()
- 273 at the 1st result sequence , and
- 234 at the 2st result sequence
3. There is always 2 last character reprinted at the end of readsensor() and devdata()
- 73 at the 1st result sequence , and
- 34 at the 2st result sequence
Kindly please give me your enlightment to fix this problem.
My IDE version : 0022
My Board : Arduino 2009 , ATMega328.
My OS : Ubuntu (Jaunty)
Sincerely
-bino-
« Last Edit: February 04, 2011, 04:17:16 am by binooetomo » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
sendvarval[0] is a pointer. It points to space that is initialized to hold one character. You are copying more than one character to that location. Oops.
Try
Code:
char sendvarval[6][10];
instead.
When you write out of bounds, you are writing over some other memory locations. Potentially you are overwriting the first character of the "=========================" string with a NULL, so when you print that memory space, only the NULL is seen, so nothing gets printed.
Logged
Indonesia
Offline Offline
Jr. Member
Arduino rocks
View Profile
PaulS ... you ARE the enlighter !!
-bino-
Logged
Pages: [1]   Go Up
Print
Jump to:
