Topic: IDE Suggestion : File naming (Read 3966 times) previous topic - next topic
binooetomo
Dear Developer.
Every time we do "save as", the IDE will :
- Create a new directory with the name we desired, and
- save the actual file inside newly created directory, and name it just like the directory name.
My Sugestion:
- save the actual file inside newly created directory, and name it "Main.pde".
Sincerely
-bino-
liudr
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Graynomad
#2
Feb 06, 2011, 06:51 am Last Edit: Feb 06, 2011, 06:52 am by Graynomad Reason: 1
I'm not sure about enforcing main.pde (or anything else for that matter). You should be able to define the file name and location anywhere you like and the working files (.HEX etc) should also go to the same position or a folder under that.
Also to have to search around users/me/roaming/??????? is crazy, and as I understand it they all get deleted when you close the IDE, presumably because otherwise you'd wind up with a 1000 temp folders.
So don't have the temp folders in the first place.
Rob Gray aka the GRAYnomad www.robgray.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
