Topic: how to rectifiy the 100 Khz sine wave signal (Read 1 time) previous topic - next topic
arulselvam
hi friends, i have 5V peak to peak output 100 Khz sine wave signal from sensor, i want to rectify this signal as DC how i can achieve this task. please help me
jremington
#1
Nov 09, 2017, 10:35 pm Last Edit: Nov 09, 2017, 10:35 pm by jremington
A diode is often used to rectify signals.
If you want to read the signal directly with the ADC, then offset the signal by 2.5V DC, as shown in this AC voltage monitor circuit.
raschemmel
Full Wave Bridge Rectifier
D1 -D4 = 1n4001 diodes
C = 470uF to 1000uF
(values based on low current load. Since load current or application were not specified, power supply cannot be designed specifically for a load that was not specified.
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
Wawa
Depends what you want to do with that signal.
Only detect if it's there?
Measure it's peak/peak voltage, or frequency?
Is it a digital 0-5volt signal, or AC centered around ground?
@raschemmel
A 1N400x is too slow for 100kHz.
Leo..
arulselvam
@raschemmel
Leo..
i want to measure peak to peak value its ac signal from xr2206
arulselvam
can i use UF4007 diode to rectify this signal
larryd
Try 1N4148 (1N914), experiment with output capacitors and load values.
No technical PMs.
The last thing you did is where you should start looking.
Wawa
Yes, a 1N4148 would be better
And reduce the buffer cap to 100n.
Leo..
raschemmel
100,000 Hz/60 Hz = 1666
1000 uF/1666 = 0.6 uF
Wawa
Smoothing cap value needed depends on load resistor value (you need one).
If there is no load (very high impedance input pin), then rectified voltage on the cap will stay there for a long time.
As larryd said: experiment with output capacitors and load values.
You might not need a full bridge if XR2206 and Arduino grounds are shared.
Leo..
JohnRob
Do you have an accuracy goal.  With a 5V P-P signal the diode drop 0.3 to 0.5 v is a large portion of you signal.  Is that adequate for what you need?
There are precision rectifier circuits which basically is an opamp with the diode inside the feedback loop.  For a 100k Hz you would have to carefully choose your components.
Please do not PM me with thread based messages.  If your thoughts are worth responding,  the group should benefit from your insight.
MarkT
At least use schottky diodes to rectify, not 1N4148 or 1N400x series!!
6v6gt
What sensor (link) and what are you going to do with the rectified  result ?
You may be able to attempt a signal processing treatment of your input signal eg subtracting 2.5 and returning the absolute value of the voltage, but an Arduino may be too slow for any elaborate processing here.
raschemmel
#13
Nov 11, 2017, 11:29 am Last Edit: Nov 11, 2017, 11:31 am by raschemmel
EXAR 2206
(Supply Voltage = 10Vdc, hence +/- 5V AC out)
allanhurst
Do you have an oscilloscope? - that's the obvious way...
Allan
