Topic: grounding and potentiometers? (Read 1 time) previous topic - next topic
salatmensch
hi there,
i am having problems with hooking up a simple 10k potentiometer to the arduino. if i touch the potentiometer i get very stable values but as soon as i take my hand of it it starts to become unstable. i am suspecting this is due to improper grounding. would this effect stop if i would screw the potentiometer into a metal box? (and if i would use proper connectors and wires to the arudino)?
here my script:
Code: [Select]
#include <MIDI.h>
#define LED 13    // LED pin on Arduino board
  pinMode(LED, OUTPUT);
  MIDI.begin(1);            // Launch MIDI with default options
  int inFader         = 0;
  static int prevVal  = 0;
  inFader    = (inFader + analogRead(0));
  delay(1);
  delay(1);
  delay(1);
  inFader    = (int) (inFader * 0.25) * 0.125;
  if (inFader != prevVal) {
     MIDI.sendControlChange(10, inFader,1); //cc, val, ch; 0 = ch16!
     prevVal = inFader;
cr0sh
I'm not sure why you're reading the input multiple times then "averaging" the values (not sure why you're averaging the four measurements, then taking 1/8 of that measurement, either) - unless you were trying to combat what you are seeing.
It may be that you need better grounding (or shielding, actually) - but I really suspect that it may be those funky paperclips inducing/picking up noise, adding parasitic capacitance, extra resistance, who knows what...
I would first try removing those from the leads, stripping and re-tinning the ends of the leads well to be able to insert them directly into the headers (or solder on short lengths of solid -copper- wire for the ends).
Good luck.
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
