Topic: C# Form read data LAG (Read 600 times) previous topic - next topic
qkqk01qk
I am now making a C# Interface to read the data from Arduino (Serial.print).
However, when the C# Form ran about over 1 minute, it is so lag and even cannot control the Form.
How to solve this problem? maybe it is about memory?
Arduino: "Serial.print" a number with "0.5s" interval
C#: using timer and SerialPort to read with "0.5s" interval
C# code:
Code: [Select]
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
namespace WindowsFormsApp2
    public partial class Form1 : Form
        public SerialPort myport = new SerialPort();
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            myport.BaudRate = 9600;
            myport.PortName = "COM8";
            myport.Open();
            timer1.Interval = 500;
        public void timer1_Tick(object sender, EventArgs e)
            string data_rx = myport.ReadLine();
            label1.Text = data_rx;
            timer1.Start();
Arduino code
Code: [Select]
int TouchSensor = 0;
  pinMode(TouchSensor, INPUT);
  if(digitalRead(TouchSensor)==HIGH)       //Read Touch sensor signal
    Serial.println("1");
    Serial.println("0");
Thanks! :)
horace
rather tha usinga timer event use a SerialPort.dataReceived event, e.g.
Code: [Select]
private void myport_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
however, you should avoid accessing GUI components from the SerialPort event handler as it is not thread safe
PaulS
Quote
You can use the Invoke() mechanism to allow thread-safe update of GUI components.
qkqk01qk
Finally I found a solution and running smooth.
http://forum.arduino.cc/index.php?topic=199056.0#msg1482780
Thanks
