Topic: Timestamping with sensor inputs (Read 824 times) previous topic - next topic
YoungsterSP
I want to start a project with a load cell and I want the load cell to output a value into a serial monitor on my computer. One of the problems I'm running into is that the project requires the serial monitor to show the time. I was thinking a timestamp or something. Is there another application I can use? Or is there a way I can use my PC time, timestamp each output? I do not want to use the milli function either.
sterretje
What you want and what you need are two different things ;) If it's just a relative time, use millis().
You can add a RTC; there is also a software RTC library (simulating a RTC).
RealTerm is an alternative to the serial monitor; it seems to support timestamps but I run an older version and can't test. If your OS is not Windows, you might have to search for alternatives that support timestamps; google e.g. terminal program with timestamp and add your OS.
And lastly you can write a application for the PC that adds a timestamp when it receives data.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Nick_Pyner
#2
Nov 14, 2017, 03:59 am Last Edit: Nov 14, 2017, 04:02 am by Nick_Pyner
Yes. Simply ditch the serial monitor and use a proper terminal programme instead. I use RealTerm, there are others, all free.
You can then timestamp each line of data using the PC clock. You can also (gasp!) record the data to a CSV file.
Another option is to use PLX-DAQ, which enables Excel to work as terminal. also with built-in timestamping and recording. It can also give you live graphs.
http://forum.arduino.cc/index.php?topic=437398.0
acboother
My ESM4 has sample code in the download for getting time & date from a PC into the Arduino and also automatically getting the monitor to put in a timestamp. You may also find that ESM4 will do a lot of what you are trying to achieve.
https://forum.arduino.cc/index.php?topic=500805.0
rsfoto
This might be a solution for your Problem too
https://www.megunolink.com/documentation/how-do-i-documentation/syncing-time-megunolink/
regards
