Topic: Serial Communication with PC Software problem -- FIXED (Read 3459 times) previous topic - next topic
mandim
Feb 05, 2011, 06:11 pm Last Edit: Feb 10, 2011, 12:20 pm by mandim Reason: 1
Hi!!
I'm new to the forum and to the Arduino programming and I would like your help.
I'm trying to implement a communication protocol between a software runnig at the PC and Arduino.
I've written a code for getting/sending commands from/into the Arduino but I'm facing a strange problem.
The first request response must be:
request -> #:GS#
response->13:25:54#
My code is this:
Code: [Select]
void loop(){
 int index = 0;//the incoming message length
 while (Serial.available()){//check for incoming message
   delay(20);// Each character does 1ms in order to transfer
   cmd[index] = Serial.read();//Stores the word and decreases the buffer
   delay(1);
   index++;
 if (index > 0){
   //Serial.print(cmd);
   if (strcmp(cmd, "#:GS#")  == 0){
     Serial.print("13:25:54#");
When I test this with the Serial monitor it works well but in the PC software I cannot get the response.
This is due to the fact that the cmd array stores strange chatacters because when I uncomment the Serial.print(cmd) I get strange characters and the comparisson inside the if fails.
Although this doesn't happen when I test it with Serial Monitor.
Do you know what cause the problem?
I'm getting crazy with this. :~
sentryGun53
It might help if we could see the code you are running on the PC.
Suggestions:
Do you have the PC software set to use the right baud rate?
Are you sending the #:GS# request in the correct datatype (byte, DEC, HEX, etc.)
Build your own sentry gun! http://psg.rudolphlabs.com
mandim
Thanks for your reply!
Unfortunatelly the PC program is commercial (it's not developed by me) and the protocol is fixed.
I have a monitoring program which I can see the requests/responces messages and I saw that the PC program sends the command properly (from the monitoring program I see that the program sends: "#:GS#").
From the specification of the protocol it says that the baud rate is 9600 and messages must be Hex datatyped so I assume that the PC program would be properly configured (or not?).
PaulS
Your Arduino code is expecting all the serial data to arrive while you are delaying. That may not be the case. If the incoming serial data is a fixed number of bytes, simply do nothing is Serial.available() returns a smaller value.
When you do add a character to the array, you should add a NULL immediately after it:
Code: [Select]
    index++;
    cmd[index]  = '\0';
You might need to test the value that Serial.read() returns, before stuffing it in the array.
mandim
Ok,
I've done some debugging and the Serial.read() gets odd characters and stores it to the array.
For example when I send a '#' char the Serial.read() stores a '.' char.
I think this is the cause of the problem.
How do I fix this?
PaulS
Quote
How are you sending the '#' character?
mandim
It is sent by the PC program.
Anyway, I found a library called Messenger here http://www.arduino.cc/playground/Code/Messenger.
It says that "is a "toolkit" that facilitates the parsing of ASCII messages"
Is it going to solve this issue?
PaulS
Quote
In other words "I've made some code changes, but I'm not going to show them to you. It still doesn't work, though, and I still need help."
Quote
No. If there is a mismatch between what the PC is sending and what you think the Arduino is receiving, a library that facilitates the collection and parsing of the data isn't going to magically make the data correct.
mandim
Sorry, my mistake.
The code is this:
Code: [Select]
void loop(){
    Serial.print(Serial.read());//Need to fix this
    //cmd[index] = Serial.read();//Stores the word and decreases the buffer
    //delay(1);
    //index++;
  if (index > 0){
    Serial.print(index);
I'm not able to see the exaclty what the PC programm sends and the only way is by a monitoring programm.
This is the request/reaponse from the monitoring program:
PaulS
What does this (in place of the Serial.print statement you have now) print in the serial monitor?
Code: [Select]
Serial.println(Serial.read(), DEC);
mandim
Code: [Select]
Hi! I've tried the above code and I got "29..77..141.." as response. Is it good or bad?  :smiley-red:
mandim
I just figoured out what was the cause of the problem.
I have to open the PC program first and then to plug in the usb cable to the Arduino board.
I don't know why is this happening but I think its not a problem.
Now I see that the commands are being sending and reciving properly without any encoding (i.e. DEC).
Thanks for your help. Now I'm ready to implement the communication protocol XD.
Maybe I will use the Messenger library.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
