Loading...
Pages: [1]   Go Down
Author Topic: PID with Processing front end  (Read 1017 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am trying to use the PID library on the Arduino and control it with the Processing interface. I had this working at one point over the summer, but I had to get a new computer and lost the files that I was previously using. There is another thread related to this but I am unable to post in it. http://arduino.cc/forum/index.php/topic,6998.30.html#lastPost
I can get the Arduino file compiled and uploaded fine, and the Processing interface to load, but it doesn't graph any of the inputs/outputs and I can't change any of the parameters. I can't paste all of the code for Processing interface because it is too long so I just uploaded the file that I am using.
Here is the code I am using for the Arduino:
Code:
 * PID Simple Example (Augmented with Processing.org Communication)
 * Reading analog input 0 to control analog PWM output 3
#include <PID_Beta6.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
int inputPin=0, outputPin=3;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1);
unsigned long serialTime; //this will help us know when to talk with processing
  //initialize the serial link with processing
  //initialize the variables we're linked to
  Input = analogRead(inputPin);
  Setpoint = 100;
  //turn the PID on
  myPID.SetMode(AUTO);
  //pid-related code
  myPID.Compute();
  analogWrite(outputPin,Output);
  //send-receive with processing if it's time
  if(millis()>serialTime)
    SerialReceive();
    SerialSend();
    serialTime+=500;
 * Serial Communication functions / helpers
union {                // This Data structure lets
  byte asBytes[24];    // us take the byte array
  float asFloat[6];    // sent from processing and
}                      // easily convert it to a
foo;                   // float array
// getting float values from processing into the arduino
// was no small task.  the way this program does it is
// as follows:
//  * a float takes up 4 bytes.  in processing, convert
//    the array of floats we want to send, into an array
//    of bytes.
//  * send the bytes to the arduino
//  * use a data structure known as a union to convert
//    the array of bytes back into an array of floats
//  the bytes coming from the arduino follow the following
//  format:
//  0: 0=Manual, 1=Auto, else = ? error ?
//  1-4: float setpoint
//  5-8: float input
//  9-12: float output
//  13-16: float P_Param
//  17-20: float I_Param
//  21-24: float D_Param
void SerialReceive()
  // read the bytes sent from Processing
  int index=0;
  byte Auto_Man = -1;
  while(Serial.available()&&index<25)
    if(index==0) Auto_Man = Serial.read();
    else foo.asBytes[index-1] = Serial.read();
    index++;
  // if the information we got was in the correct format,
  // read it into the system
  if(index==25  && (Auto_Man==0 || Auto_Man==1))
    Setpoint=double(foo.asFloat[0]);
    //Input=double(foo.asFloat[1]);       // * the user has the ability to send the
                                          //   value of "Input"  in most cases (as
                                          //   in this one) this is not needed.
    if(Auto_Man==0)                       // * only change the output if we are in
    {                                     //   manual mode.  otherwise we'll get an
      Output=double(foo.asFloat[2]);      //   output blip, then the controller will
    }                                     //   overwrite.
    double p, i, d;                       // * read in and set the controller tunings
    p = double(foo.asFloat[3]);           //
    i = double(foo.asFloat[4]);           //
    d = double(foo.asFloat[5]);           //
    myPID.SetTunings(p, i, d);            //
    if(Auto_Man==0) myPID.SetMode(MANUAL);// * set the controller mode
    else myPID.SetMode(AUTO);             //
  Serial.flush();                         // * clear any random data from the serial buffer
// unlike our tiny microprocessor, the processing ap
// has no problem converting strings into floats, so
// we can just send strings.  much easier than getting
// floats from processing to here no?
void SerialSend()
  Serial.print("PID ");
  Serial.print(Setpoint);
  Serial.print(" ");
  Serial.print(Input);
  Serial.print(" ");
  Serial.print(Output);
  Serial.print(" ");
  Serial.print(myPID.GetP_Param());
  Serial.print(" ");
  Serial.print(myPID.GetI_Param());
  Serial.print(" ");
  Serial.print(myPID.GetD_Param());
  Serial.print(" ");
  if(myPID.GetMode()==AUTO) Serial.println("Automatic");
  else Serial.println("Manual");
Logged
Pages: [1]   Go Up
Print
Jump to:
