Topic: Arduino max current (Read 2956 times) previous topic - next topic
KoudyDevCZ
I have a simple question...
How much of current i can get from arduino mega if is connected to pc?
Thank Koudy
drone
Thank Koudy
From what on the Arduino mega?
From the 5V connector, from one pin, or from all pins combined?
!c
retrolefty
Thank Koudy
The ultimate limit is 500ma due to USB standards and the polyfuse wired used in the board. Now using all 500ma is only possible with careful understanding of pin limits, total chip limits, and proper use of external switching devices that use the arduino +5vdc voltage.
Lefty
KoudyDevCZ
Thank Koudy
!c
From the 5V connector and from all pins combined ... ?
Koudy
Grumpy_Mike
Quote
200mA is the maximum of all the combined pins, no one pin to exceed 40mA
These are absolute maximum ratings.
The data sheet says:-
Quote
Stresses beyond those listed under "Absolute Maximum Ratings" may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
The 5v rail if driven from the USB then with a 500mA limit less that that.
If driven from the on board regulator then it depends on what the input voltage is, the limit is given by the power dissipation of the regulator and is discussed here:-
http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
cmiyc
In many applications, I/O pins really should not be used as power sources (or sinks).  Your questions leads me to ask:  What are you trying to do?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
