Topic: combining programs? (Read 1 time) previous topic - next topic
whiskey
May 11, 2010, 09:26 am Last Edit: May 11, 2010, 09:27 am by whiskey Reason: 1
hi,
I'm building a robot and already I'm stuck in a rut   :-?
I've managed to get some basic movements with the arduino and a Solarbotics L298 motor driver so the next step was to add a servo that will pan from  left to right. I thought all I would have to do is copy n paste the servo code but I guess that's not the case.
Any help and simple explanation on how/why this is not working would be much appreciated!!
#include <ServoTimer1.h>
ServoTimer1 servo1;
// Solarbotic L298 Motor Controller pins
int enablePin = 2;
int LeftMotorForward = 3;
int LeftMotorBackward = 5;
int RightMotorForward = 6;
int RightMotorBackward = 9;
 pinMode(enablePin, OUTPUT);
 pinMode(LeftMotorForward, OUTPUT);
 pinMode(LeftMotorBackward, OUTPUT);
 pinMode(RightMotorForward, OUTPUT);
 pinMode(RightMotorBackward, OUTPUT);
 digitalWrite(enablePin, HIGH);
 servo.attach(10);
 Serial.print("forward");
 forward();
 delay(3000);
 Serial.print("pause");
 digitalWrite(enablePin, LOW);
 delay(2000);
 Serial.print("backwards");
 backwards();
 delay(3000);
  servo1.write(180);
  servo1.write(0);
 void forward()
 digitalWrite(LeftMotorForward, LOW);
 analogWrite(LeftMotorBackward, 200);
 digitalWrite(RightMotorForward, LOW);
 analogWrite(RightMotorBackward, 200);
 digitalWrite(enablePin,HIGH);
 void backwards()
 analogWrite(LeftMotorForward, 200);
 digitalWrite(LeftMotorBackward, LOW);
 digitalWrite(RightMotorBackward, LOW);
 analogWrite(RightMotorForward, 200);
Just to be clear, the motor driver is working and the servo does work when it's on it's own.
The error I get when compiling is:
In static member funtion 'static void ServoTimer: :seizeTimer()':
and...
error: 'TIMSK' was not declared in this scope
thanks for taking a look!  8-)
mem
#1
May 11, 2010, 09:56 am Last Edit: May 11, 2010, 10:01 am by mem Reason: 1
replace :
ServoTimer1 servo1;
with :
#include <Servo.h>
Servo servo1;
change :
 servo.attach(10);
to :
 servo1.attach(10);
and it looks like you may have an unmatched pair of braces in the loop code
fdufnews
You should suppress the two braces in the middle of your loop()
 forward();
 delay(3000);
 delay(2000);
 backwards();
 delay(3000);
  servo1.write(180) ;   |                     |
  delay(1000);          | This part of code   |
  servo1.write(0);      | is never executed   |
  delay(1000);          | because of that -----
mem
#3
May 11, 2010, 01:22 pm Last Edit: May 11, 2010, 01:24 pm by mem Reason: 1
the problem with those braces is not that code is never executed, they prevent the code from compiling because the lines after the closing brace are not in a function
whiskey
#4
May 12, 2010, 05:17 am Last Edit: May 12, 2010, 05:20 am by whiskey Reason: 1
thanks for the help!
I got it up and working but found it to be a little too fast, I need it to go about half the speed that it was,  it took me a few hours but finally got it figured it out.  :)  in the end I ended up doing the same thing that you would to an LED during  PWM.
The problem I have now is that it runs the code in the order it was written, meaning it only pans after the motor commands and only does this once, then starts the loop all over again?
If someone can point me in the right direction it would be appreciated!
#include <Servo.h>
Servo servo1;
int enablePin = 2;
int servoVal;  //variable to make servo pan slowly (not sure if it needs to be here?)
 servo1.attach(10);
 // motor controller commands
   forward();
   delay(3000);
   delay(2000);
   backwards();
   delay(3000);
   delay(2000);
   // servo pan commands
 Serial.println("looking left");
  for(int x=40; x<=140; x++){   // pans 1 degree at a time till it reaches it's max limit
   int servoVal = x;           // the degrees can be changed to your liking!
   servo1.write(x);
   delay(10);
 Serial.println("looking right!");
  for(int x=140; x>=40; x--){   // pans from one limit to the other
   int servoVal = x;           // this creates a varible
   servo1.write(x);           // writes the value of the varible
   delay(10);
 // motor controller funtions
 void forward() // might need to swap forward/reverse depending on your bot
 void backwards() // might need to swap forward/reverse dending on your bot
mem
Usually there is a  problem if the code does not run in the order written  ;)
Can you provide some more details about what should happen
Grumpy_Mike
It's all those delays. Look up the blink without delay example and apply it to your code.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
Only if you are trying it then put a resistor in the LED
whiskey
#7
May 22, 2010, 09:07 pm Last Edit: May 22, 2010, 09:08 pm by whiskey Reason: 1
so I'm back and now with a little more knowledge under my belt, thanks for the link grumpy mike!
BUT... for some reason I still can't get the proper outcome, I know grumpy has said it's because of my delay's and it actually makes "sense" that they are not needed but without them the pan does a very sharp move then that's it.
here's my assumption on what's going on:
~ I'm creating my "current time"
~ I'm subtracting my current time from my "previous time" (which at the moment is zero)
~ if the statement is true it runs "pan servo"
this is the problem...
~ "pan servo" runs it's full cycle from the min-max-min degrees
~ loop starts over again running the motors then pan
... what I need it to do is move 1 degree "tag it's time", wait 10 millis, move to the next degree, etc... all while the other programs are running (in other words the panning need to be done in the background).
... it seems like I need to replace "delay" with somthing like "previous time" so it will tag it's time in 10 millisecond increments? If you have a look in the program you can see that I tried that but I get the error:
"Ivalue required as left operand of assignment"
I'm stumped once again, but in a god way! any help with this would be appreciated.
here's my code, I took out the motor commands to minimize the clutter.
#include <Servo.h>
Servo servo1;
long servoDelay = 10;  // intervals at which to pan servo (milliseconds)
unsigned long previousTime; //represents the timing of the "cycle"
unsigned long currentTime = millis();
 if(currentTime - previousTime > servoDelay){  // if the time exceeds 10 milliseconds run "panServo"
     panServo();
     previousTime = currentTime; // "resets" the loop time
// pan servo funtions
void panServo()
   servo1.write(x);
   //delay (10);
  millis() = previousTime;
   servo1.write(x);
   //delay (10);
thanks for looking 8-)
AWOL
This:
   servo1.write(x);
   //delay (10);
will simply do 100 "servo.write"s and 100 assignments to "millis()" (which is a function and therefore and illegal lvalue) without stopping.
It isn't surprising it sweeps from one end of the travel to the other.
You can't use a "for" loop for this sort of "blink-without-delay" application, you need to code the loop explicitly, kind-of turning it inside-out.
