Topic: connecting wirelessly two lilypad twinkle (Read 2635 times) previous topic - next topic
benalazarova
Hi Guys!
I am trying to understand if there is a way to connect two lilypad tiny or twinkle wireless.. i'm trying to making two object that one should send information to the other and the other should react in a certain way, is it possible ? The problem is that i have to do it as fast as possible and still have to order the lilypads.. Every hint would be useful!!
Thanks in advance
Cheers
Bena :)
CrossRoads
Sure, set up one with a 433MHz Transmitter, the second with a 433 MHz Receiver, use the Virtual Wire library to send and receiver a message.
http://www.airspayce.com/mikem/arduino/VirtualWire/
Tx:
https://www.sparkfun.com/products/10534
Rx:
https://www.sparkfun.com/products/10532
A set of the units:
http://www.yourduino.com/sunshop/index.php?l=product_detail&p=341
Also has links to VirtualWire library
Don't forget to add 17cm of simple wire for an antenna
benalazarova
Thank you, CrossRoadsm you're a life sensor !
Another question to which i cannot get a definitive enough answer: can i hook a heart rate sensor to lily twinkle and a lithium battery at the same time ?
I'm a completely noob in those things and finding the right answer, or the one that i can manage to understand is harder than i thought, so sorry if the questions sound stupid..
