Topic: Maxsonar sensors with servos (Read 1 time) previous topic - next topic
teslalucas
So i am using lv-maxsonar with 2 servos. i want to use the sensors with the servos for motion detection. I am using the sweep coding arduino offers and I know that there is a lot of code for distance reading with the sensors but i cant figure out how to get the sensors to work with the servos when i put my hand in front of the sensors. I am going to use two or three sensors so it can cover a wide range. Any assistance would be appreciated.
AWOL
Seeing your code would be a great help.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
teslalucas
Code: [Select]
i don't have any set code but this. the servo moves but it only goes to one angle and does not follow anything. The servo just moves one time once i put my hand in front of the sensor.
[#include <Servo.h>  // Library for the servo's
Servo myservotop;
Servo myservobottom;    // Object Declaration Servo
int pos = 0;
  Serial.begin(9600);  // start servo communication
  myservotop.attach(9);     // servo that pin 9
  myservobottom.attach(8);
void motion()
  for(pos = 40; pos < 160; pos += 2)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservotop.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                                    // waits 15ms for the servo to reach the position
  for(pos = 40; pos>=0; pos-=2)
  {myservobottom.write(pos);
    delay(15);
  for(pos = 40; pos>=0; pos-=2)     // goes from 180 degrees to 0 degrees
    delay(15);
  }  void loop()
//in our quadrant (90 degrees) to be launched about 1.5 meters (60 inches)
//Sensor everything closer than about 5 inches by 5 inches determined as
//So we map the values of 10-120 0-90 degrees
  int minDistance = 10;
  int maxDistance = 120;
  int spread = maxDistance - minDistance;
  int quadrant = 180;
  int distance = analogRead(0);  // We load value sensor
  // certainly position servo
  int position = (float)quadrant / (float)spread * (float)distance;
  // limit Quadrant (90 degrees)
  position = min(position, 180);
  position = max(position, 50);
  // set position servo
  myservotop.write(position);
  myservobottom.write(position);
  // value send after serial lynx
  Serial.print(distance);
  Serial.print(":");
  Serial.println(position);
  // wait 1/5 second do go further measurements
  // hand will be less bound
  delay(200);
