Topic: Wifly LED control delay issues (Read 1 time) previous topic - next topic
lapoza
I have gotten a wifly to run a simple web server, and it is suppose to have 3 pushbuttons.  Sometimes it loads all 3 and sometimes it only loads the first two, Not sure what is causing that problem.  Im new to everything and self taught, but if anyone can see what is causing that it would be greatly appreciated.
the main thing I am trying to work out is, when I select a pushbutton and hit enter, There is a delay in how long it takes for the shiftbrites to change their pattern, and it also locks up on the last cycle while it processes.  So if i am running a strobe pattern (pattern 3) and when i hit submit, it is currently off, it stays off until it starts the next pattern.  Or if it is on it quits strobing and stays solid for a second, and then changes to the next pattern. I would like this to be instant, I'm hoping someone can see something obvious that is causing the delay and can point me in the right direction.  Here is the code:
Code: [Select]
// Set pins to outputs and initial states
 SpiSerial.begin();
 //exit CMD mode if not already done
 SpiSerial.println("");
 SpiSerial.println("exit");
 //set into CMD mode
 SpiSerial.print("$$$");
 //set authorization level
 SpiSerial.println("set w a 3");
 //set passphrase
 SpiSerial.println("set w p bdeckwifi");
 //set localport
 SpiSerial.println("set i l 80");
 //disable *HELLO* default message on connect
 SpiSerial.println("set comm remote 0");
 //join wifi network <ssid>
 SpiSerial.println("join testing");
 delay(5000);
 //exit CMD mode
 pinMode(datapin, OUTPUT);
 pinMode(latchpin, OUTPUT);
 pinMode(enablepin, OUTPUT);
 pinMode(clockpin, OUTPUT);
 digitalWrite(latchpin, LOW);
 digitalWrite(enablepin, LOW);
void SB_SendPacket() {
 if (SB_CommandMode == B01) {
   SB_RedCommand = 127;
   SB_GreenCommand = 110;
   SB_BlueCommand = 110;
 SB_CommandPacket = SB_CommandMode & B11;
 SB_CommandPacket = (SB_CommandPacket << 10)  | (SB_BlueCommand & 1023);
 SB_CommandPacket = (SB_CommandPacket << 10)  | (SB_RedCommand & 1023);
 SB_CommandPacket = (SB_CommandPacket << 10)  | (SB_GreenCommand & 1023);
 for (int j = 0; j < 32; j++) {
   if ((SB_CommandPacket >> (31 - j)) & 1) {
     DATPORT |= (1 << DATPIN);
   else {
     DATPORT &= ~(1 << DATPIN);
   CLKPORT |= (1 << CLKPIN);
   CLKPORT &= ~(1 << CLKPIN);
void SB_Latch() {
 delayMicroseconds(1);
 LATPORT |= (1 << LATPIN);
 ENAPORT |= (1 << ENAPIN);
 ENAPORT &= ~(1 << ENAPIN);
 LATPORT &= ~(1 << LATPIN);
void WriteLEDArray() {
 SB_CommandMode = B00; // Write to PWM control registers
 for (int i = 0; i < NumLEDs; i++) {
   SB_RedCommand = LEDChannels[i][0];
   SB_GreenCommand = LEDChannels[i][1];
   SB_BlueCommand = LEDChannels[i][2];
   SB_SendPacket();
 SB_Latch();
 SB_CommandMode = B01; // Write to current control registers
 for (int z = 0; z < NumLEDs; z++) SB_SendPacket();
 SB_Latch();
void rotate(){
 val=30;
 //val= analogRead(analogPin);
// Example loop to cycle all LEDs through primary colors
   if (program==1){
   LEDChannels[i][0] = 1023;
   LEDChannels[i][1] = 900;
   LEDChannels[i][2] = 750;
 WriteLEDArray();
      delay(val);}
      LEDChannels[i][0] = 0;
      LEDChannels[i][1] = 0;
      LEDChannels[i][2] = 0;
      WriteLEDArray();
      delay(val);}}
  else if(program==2){
      val=30;
      for (int k = 0; k <60;k++) {
      i=k ;
      int a=i+1;
      int b=a+1;
      int c=b+1;
      int d=c+1;
      LEDChannels[0][0] = ai[i][0];
      LEDChannels[0][1] = ai[i][1];
      LEDChannels[0][2] = ai[i][2];
      LEDChannels[1][0] = ai[i][0];
      LEDChannels[1][1] = ai[i][1];
      LEDChannels[1][2] = ai[i][2];
      LEDChannels[2][0] = ai[a][0];
      LEDChannels[2][1] = ai[a][1];
      LEDChannels[2][2] = ai[a][2];
      LEDChannels[3][0] = ai[a][0];
      LEDChannels[3][1] = ai[a][1];
      LEDChannels[3][2] = ai[a][2];
      LEDChannels[4][0] = ai[c][0];
      LEDChannels[4][1] = ai[c][1];
      LEDChannels[4][2] = ai[c][2];
      LEDChannels[5][0] = ai[c][0];
      LEDChannels[5][1] = ai[c][1];
      LEDChannels[5][2] = ai[c][2];
      LEDChannels[6][0] = ai[d][0];
      LEDChannels[6][1] = ai[d][1];
      LEDChannels[6][2] = ai[d][2];
      LEDChannels[7][0] = ai[d][0];
      LEDChannels[7][1] = ai[d][1];
      LEDChannels[7][2] = ai[d][2];
      LEDChannels[8][0] = ai[b][0];
      LEDChannels[8][1] = ai[b][1];
      LEDChannels[8][2] = ai[b][2];
      LEDChannels[9][0] = ai[b][0];
      LEDChannels[9][1] = ai[b][1];
      LEDChannels[9][2] = ai[b][2];
        WriteLEDArray();
        delay(val);}}
  else if(program==3){
 val = 30;
      //val = analogRead(analogPin);
   for (int j1 = 0; j1 < NumLEDs; j1++) {
      LEDChannels[j1][0] = 1023;
      LEDChannels[j1][1] = 1000;
      LEDChannels[j1][2] = 750;
    WriteLEDArray();
    delay(val);
      LEDChannels[j1][0] = 0;
      LEDChannels[j1][1] = 0;
      LEDChannels[j1][2] = 0;
      WriteLEDArray();
      delay(val);
 if (rot==1){
  rotate();
// Create a client connection
 Client client = server.available();
 if (client) {
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
       //read char by char HTTP request
       if (readString.length() < 30)
         readString += c; //store characters to string
       //if HTTP request has ended
       if (c == '\n')
         // check if LED should be lighted
         delay(100);
        /* int locateQuestionmark = readString.indexOf('?');
         Serial.println (readString);
         Serial.println ("The index of the ? in the string " + readString + " is " + locateQuestionmark);
         Serial.println(readString.substring(6,9));*/
         // now output HTML data starting with standart header
         client.println("Content-Type: text/html");
         client.println();
         //set background to yellow
         client.print("<body style=background-color:grey>");
         //send first heading
         client.println("<font color='red'><h1>  WEB ARDUINO TEST</font></h1>");
         client.println("<hr />");
         //controlling led via checkbox
         client.println("<h1>LED control</h1>");
         //address will look like http://192.168.1.110/?L=1 when submited
         //client.println("<form method=get name=LED><input type=checkbox name=L value=1>LED<br><input type=submit value=submit></form>");
         client.println("<form method=get name=LED><input type=checkbox name=L value=2>LED<br><input type=submit value=submit></form>");
         client.println("<form method=get name=LED><input type=checkbox name=L value=3>LED<br><input type=submit value=submit></form>");
         client.println("<br />");
         if (readString.substring(6,9) == "L=1")
         {program=1;
         if (readString.substring(6,9) == "L=2")
           program=2;
         if (readString.substring(6,9) == "L=3")
           program=3;
         if (readString.substring(6,9) == "L=3"||"L=1"||"L=2")
         {rot=1;}
       Serial.println("The current program is" + program);
         //clearing string for next read
         readString="";
         //stopping client
         client.stop();
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
