Topic: Speakjet Control Code Mode (Read 606 times) previous topic - next topic
elsan1967
Hi All, I've been experimenting with a SpeakJet IC and it's all working pretty much as expected except I simply can not put it into "Serial Control Mode" so I can access the registers, EEPROM etc. This is done by sending an escape code with a node number to the SpeakJet
    sjSerial.print ("\0");
along with the "code" to get it to change things. At it's simplest I just send the code
    sjSerial.print ("V"); //ack (SpeakJet says "ready")
and then
    sjSerial.print ("X"); //exit
to exit SCM.
The SpeakJet just ignores the code above when I send to it, ie it doesn't say "ready". It doesn't attempt to "say" the characters I assume it's doing "something", just not what I want. I've tried all sorts of variations, sending the characters as HEX, DEC etc, delays between sending the chars, but no joy. I've pretty much run out of idea's on what else to do. I've tried sending the reset code "W" and the stop/start codes "S" and "T" but these too are just ignored.
I can send it
  sjSerial.println ("\xFD"); //gun shot sound
and it does play the gun shot sound so it recognises the escape character OK.
I'm using the #include <SoftwareSerial.h> lib.
The documentation for the SpeakJet is here...
http://www.speechchips.com/downloads/speakjetusermanual.pdf
If anyone has any idea's I would love to hear them, I'm absolutely stumped.
PaulS
Quote
When the SCP module detects the Escape character ( \ ), the
next character received (the control value) is used to set the
serial port's operating mode.
That looks to me like you have to send TWO characters - a backslash and another character, and the device puts them together. Instead of "\0", try sending "\\0".
Delta_G
To send the backslash you'd have to escape it too.
"\\\0"
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
elsan1967
@PaulS and @Delta_G yes that's solved it. The \\ is the required combination that works.
Odd though I did think I tried the double escape quite early on but maybe I didn't have something else quite right.
Thanks!
PaulS
"\\\0"
That's going to send a backslash and a NULL, not a backslash and a 0 that the other end can then interpret as a NULL.
