Topic: print/println bug while passing in chars (Read 2898 times) previous topic - next topic
ArduDano
I encountered some bizarre behavior when print-ing the result of a function that returns a char.
Code: [Select]
char readReg(char addr)
  char result;
  digitalWrite(pinCS, LOW);
  SPI.transfer(addr | 0x80);
  result = SPI.transfer(0x00);
  digitalWrite(pinCS, HIGH);
  return result;
void loop(){
  Serial.println(readReg(0x00), HEX); // println does NOT handle this very well!
prints out "FFFFFF55" which is not correct. I would have expected either "55" or "00000055".
In order to get the correct output, I have to add:
Code: [Select]
  Serial.println(0xff & readReg(0x00), HEX); // this works OK
just as a note, this does not work either:
Code: [Select]
char a = readReg(0x00);
  Serial.println(a , HEX); // println does NOT handle this very well!
but this works fine:
Code: [Select]
  char a = 0x55;
  Serial.println(a , HEX); // works ok
but this does not:
Code: [Select]
  char a = 0xff & readReg(0x00);
  Serial.println(a , HEX); // total crap!
So weird!
robtillaart
I tried to reproduce but it worked all as expected (partly simulated) with Arduino 2009 && IDE 0021. A dive into the code of print() shows that the char is casted to a long before printing when using base HEX. For sources of print see C:\Program Files (x86)\arduino-0021\hardware\arduino\cores\arduino\print.cpp
3 questions:
- which arduino are you using?
- which ide version?
- is this happening in a big program that maybe runnning out or RAM?
Rob
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Msquare
char is a SIGNED value. So anything above 127 will have the signbyte extended into the long. Just use byte b = c ; or similar and then you do not get the leadings FFs.
robtillaart
@Msquare
Very true, but the value appears to be 0x55 so sign extention should result in 0x00000055 and not 0xFFFFFF55, ...?
@ArduDano
Can you post your complete code?
Rob Tillaart
Udo Klein
I think Msquare already got the point, char is a signed 8bit integer. The value you are printing is probably 0xAB (which equals -0x55)
To clarify this issue, what is the output of
Code: [Select]
Serial.println((uint8_t) readReg(0x00), HEX);
If the output is AB then everything should become clear.
Udo
Check out my experiments http://blog.blinkenlight.net
